How long does rtv need to dry?
Jason845845
364
Kingston, Ny
installing new stove this afternoon, I need to silicone the appliance adaptor, the rest of the piping is already sealed. How long does it need to dry before using the stove?
Why are you using RTV? That will stink to high heaven for a long time.
Dosent need to dry. We used to use it on boiler and furnace clean out plates and restart the immediately. Next years service it was still sealed perfectly
I let mine dry over-night, but that's probably overkill. I believe you'll see a dry time of 24hrs recommended in most automotive applications, but that may have more to do with potential oil contamination which isn't an issue with an air seal.
When I put my stove in I used hi temp silicone on all the joints and immediately fired the stove never had any issues... I know it's not suggested to do that though
I did the same thing, now problems at all, but it sure did cure quickly:)
Jason 845 how did the install go? Where did you bye the stove?
I use silicone self bonding tape and use instantly. Easier to remove if have to. Makes nicer looking install too.
This stuff really stretches to make a tight seal. Most home improvement stores have a version of it.
Went great, first burn Is smoking is out of the house and I have to silicone my offset elbows; but man, what a difference between the englander and the harman.
The stove came from Countryside in Rhinebeck. I didn't really have a whole lot of contact with them as I knew what I want, but the owner (?), Tim is a really nice guy and the delivery guys were great.
