SmokeyTheBear
I am following this thread carefully... I don't like that the cause is unknown
We have some of the ingredients.
The stove was not on a t-stat it has 4 heat settings. It was on 2 then I topped off the hopper & set it to 3 before we went out. .
Then theres the problem. Your In def in the 4in territory and you knew that because of what manufacturer recommended. These recommendations are not there for fun and you could have hurt somebody. This is why home insurance is expensive. Sorry but it needed to be said. Im glad nobody got hurt or you didnt lose your home. I hope you make wiser decisions next time.He has an equivalent vent length of 15 in just the 90 degree bends alone and 9 in the vertical portion he is definately in 4" vent territory and creeping up on the overall limit.
If he has access to the flue at pellet stove exhaust vent level he would be better off entering the flue that way and 90 degrees and then up. That might even put him in 3" territory.
WowAre you a smoker? The first couple years that I burned pellets, I still smoked and I know a couple times a spark or hot ash would drop off a cigarette while I was filling the hopper ........
Well you are running in a restricted mode to begin with because the EVL isn't satisfied. You may have had a little or a fair amount of ash in the venting ( a lot of folks swish out their vents at the one ton mark) , not plugged but further restricting the flow. You have known negative draft issues. And you found a cover on the chute that may not have been sealed well. The stove doesn't have a hopper cover seal. It was the coldest out yet this year. And who knows what else that has not been determined yet. But just with this much, well you had a hopper fire so we don't need proof that something is pretty wrong here..Oh, no smokers. This fire defenitly crept back from the fire box and from the looks of the burn box with lots of creosote it was burning with not much air. Almost like the pipe was plugged but it's not.
I doubt that matters, they are really clean burning pellets.If it matters, I was burning some high BTU pellets that night. PWI's then I topped off with Okanagen Douglas Fir before we went out.
You put a ton through the stove and never cleaned the 3" flue? Or am incorrect?
OAK is only as good as its draft.It's not on backup, but the power did not go out as no clocks were flashing. I had a power failure before and the stove just went out. No smoke in the house. One of reason I installed the oak was to give the stove the air it needed, or so I thought.
A very long list. Maybe OAK isn't enough. I've known of homes that have needed combustion air units installed to keep a balanced pressure in them.Eyball, has a list of things to do.
