Fuel oil is down to $1.99 a gallon here, my savings burning pellets is basically 0 now. I hope that starts dropping pellet prices also. There is a good chance I'm turning the oil burner back on.
Denny
Denny
I just posted below you , I turned it off today, sick of a cold house
I believe thats on start upEven with cheaper oil I've not been too inclined to use it rather than pellets, except if the outside temps are up around 35F deg or higher. I have an oil fired forced hot air furnace. If I recall correctly the circulating blower is up around 6-7 amps. The cost of electricity has spiked 37% in MA and having the furnace run frequently would tend to run the monthly electric bill up considerably.
Just checked the manual for the furnace. 1/2hp direct drive blower rated at 7 amps (FLA). The Beckett burner indicates it's rated at 5.8 amps.I believe thats on start up
Crude went up the last two days of trading. Could the ride be over? Was a shutdown of 25% of drilling rigs in December in ND. Well head crude price dropped below $30.
I think sometime I may take a clampon ammeter to the circuit and see what it actually pulls.
Let's see if the gas and oil prices follow as shown in the link below...Just got back from town and gas price went up 6 cents or about 3%. Lets just see what happens here in 30 days.
Older AC motor.Holy cow... My ECM blower pulls about 250 watts and thats moving about 1500CFM... around in 2700 sq/ft. If its a older AC motor its pulling what its rated.
I was thinking about connecting a rheostat to my furnace and even lower the fan due to noise, but was advised not to because It could burn out my heat exchanger?
Just listened to a news piece about oil prices and the Expert predicted that all will be back to same in 12-18 months from when it started the slide. So next Christmas could have a wallet robbing grinch, high fuel prices. Ba-humbug
