- Oct 3, 2007
- 1,539
Some of you may have heard of turning a Prius into a generator already, but in case you haven't, check this out:
http://www.converdant.biz/plug-out/
As it turns out, a Prius is the most efficient way to generate power since it is essentially a rolling generator and battery bank. With one of these kits, you can draw power out of the battery, rather than directly from a generator, as with a conventional portable unit. When either the battery level drops too low or the load demand is greater than the battery can supply, the gas engine kicks in to recharge the battery/feed juice directly to the load. The result is a quiet, efficient generator that sips fuel. Right now my daily driver is a 2001 Toyota Corolla with 213K miles. I get a consistent 33 MPG out of it with a 72 mile round trip commute and a mix of highway and city driving, but I think I may be persuaded to look at a used Prius when the Corolla finally gives up.
The plan would be to use it as my daily driver and convert it so that I could use it as an emergency generator at my house via a connector cord and transfer switch when needed. Unlike my current Generac rattletrap 4800W jobsite unit, I doubt I (or my neighbors) would notice a Prius running in my driveway all night. What really appeals to me would be the possibility of using it as a portable power source for a planned off-grid cabin in Maine. Getting it there could be a bit of a challenge depending on location and time of year though Think Toyota will ever build a hybrid 4Runner?
