OhioBurner©
I've never tried running for extended periods without the blower since it seems quite noticeable it doesn't put out much heat into the room without. But your reasoning wouldn't work on my stove... unless I'm trying to burn wet wood my air control is all the way to min all times once its through startup until I'm getting ready for reload.I suspect that's the case with mine. My totally unsubstantiated theory is that the hotter firebox allows me to run with less air, resulting in longer burns. At the moment most of my loads are running with the air fully closed. That's only possible with well seasoned wood.
TE
