I got this out of my flue
From my experience If any wood or pellet boiler is left over summer without cleaning it out thoroughly ash because of it's high acidity can corrode metal when it comes in contact with moisture. Is this an indoor or outdoor boiler?
Wood ash is not acidic. In fact it is highly caustic which is the opposite end of the scale. However this doesn't mean that it is not corrosive.
What I'm seeing in the photo is more than a result of a little water getting in there IMO.
It is a out door inside a shed. I did not clean it well last summer as I used it about every two weeks to heat the pool. I did the heavy cleaning just before light off.
I have never seen any signs of rain coming down the chimney, It would show in the ash.
You're right, should have dawned on me as I take charcoal tablets when I have indigestion but than again I wasn't head of the class in Chem. 101!
Not necessarily, if rain was coming down your chimney and somehow running into these tubes the ash present would act like a sponge and hold it until it was saturated. Ash of course is bone dry and thirsty so it can pull in moisture from the air, especially if you're located in a humid climate. A rain cap might be a helpful part of preventive maintenance but a better solution is to get rid of as much ash as possible once the heating season is done with.
Me thinks...combination of moisture from either flue condensation or rain dripping down and low grade steel...but I am usually off my rocker..especially when the Pats win...
Congrats Pats fans....Seattle just gifted u one.
