Bar oil question
2PistolPacker
189
Lenexa, Ks
Does anyone use plain new 5W30 motor oil as bar oil when cutting at temps below 15 degrees? I used R&O hydro oil last time when cutting in these temps and it worked fine, but I'm out of it. What do you use for bar oil at these temperatures?
Labonville's winter grade is straight 10 weight
Straight canola. Learned that on here, cheap easy and non toxic. Cut a bit the other day at 20 F and it was fine.
Reactions: TommyTally
I mix the 5-30 motor oil 50/50 with bar oil for winter.
I have a strict policy of never cutting wood at temps below 15 degrees
Only thing I put on my bar is an empty beer mug...regardless of the temps outside
Reactions: Hasufel
winter bar oil
Reactions: 7acres
Some mfgs (e.g. RedMax) spec 10W-30 viscosity index winter to summer. For a fact, works fine down in the single-digits. It flows then, when straight 30 jells pretty solid.
To go one step further, would used cooking oil work if strained? Or not enough slippery stuff left in the oil then? I dunno if I'm that cheap ;) to try used, but I'll try new canola oil.
Yes . Used cooking oil filtered works well filtered. In cold weather I'd advise not using it or mixing it with dino or it will gel up.
Well I'm only foolish enough to still run my saw down to about -25 C (-15 F?) but we have some nice weather on the way, maybe I'll try it then. Thanks.
Reactions: 2PistolPacker
I use winter bar oil. Tends to go on sale pretty cheap here at Canadian tire in 1gal jugs.
What is your bar and chain worth to you? Packaged oil made for B&C use is pretty cheap.
Reactions: CentralVAWoodHeat
Thanks to all for answering my question. Motor oil is $4 a quart so it's out and I can't find 10w bar oil locally, so I'm going to pick up a gallon of Canola oil. I think a 60/40 mix with my 30w bar oil will be a good starting point. This mostly is for my .024 Stihl which oils slowly in cold weather anyway, my 372xp has an adjustable oiler and will work with any viscosity oil.
Funny thing, I'm looking online and the 1 liter bottles are $3.79, but I'd swear the last few times I've bought it, it was at least a buck more. What were you paying for a 1 gallon jug?
I always use straight canola; better for the environment, and my saw seems to run well with it.
Reactions: osagebow
8-10$ if I remember correct. That's when they have a sale at my local not sure about other locations
cheap atf fluid in winter months
Thought I'd come back here to give an update, in case anyone is using the search function wonder. I mixed used canola oil, strained/filtered, with a half n half ratio with winter grade bar oil (thin stuff). Temperatures while cutting have been 20-40F or about -5 to +5 C, very nice weather for around here I might add.
Bottom line, works fine. It's very slick and seems to meter just as well, if not a bit more than winter grade bar oil. Less tacky, but the bar didn't seem to be any hotter than previous cutting without it in the mix. A few blips on the throttle and it sprays like you would expect it to, off the end of the bar.
For light duty cutting or bucking, I can see no problem mixing some of this in with regular bar oil. I was felling, limbing, and bucking green poplar 5-9" size. I'm not saying I'd advise it's use with a chainsaw mill or forestry work, but for light duty, it's a go.:)
At the very least, I cut the cost of bar oil in half for myself, which is good. Cause I'm frugal.
Reactions: D8Chumley
High of 24F today but the wind....I have never seen winter bar oil, all the places I have been to have just the one type. If it gets too cold then I will wimp out but sunny and 10F is OK.
Oh boy, here we go again! I think, based on the wide variety of crap people put in their saws and report as 'working great', if it is liquid at the temperature you're cutting at - and has some slight lubricating properties - you're gonna be fine. Vegetable oil, mineral oil, baby oil, whale oil, diesel, transmission fluid, bear fat - whatever...just keep some lube in there!
Reactions: Mag Craft
What he said. I just bought a new deep fryer and plan to get my money's worth out of the oil.
