Muffler Mod on Stihl MS250--Removing Limiter
WarmGuy
519
Far Northern Calif. Coast
I'm about to pull the trigger on a muffler mod on my Stihl MS250.
My understanding is that I enlarge the muffler hole, open up the muffler baffle holes with a screwdriver, and eliminate the limiter for the high-speed adjustment.
To remove the limiter do I cut off the metal extension (red arrow) or remove or deform the plastic thing (yellow arrow)?
Thanks,
Correct, Look over on Arboristsite in the chainsaw section and you'll get detailed info. Just know if you go there, you have one saw now-you will soon have several=CAD, I warned you :) I had two, then all the sudden seven...
The answer is that you pull off the plastic thing indicated by the yellow arrow. Place a small screwdriver between the plastic thing and the body of the carburetor and twist. It will come out a bit, and then you can pull it off with a pair of needle-nosed pliers. It slides off easily.
And it worked great. Started right up. I set the high speed adjustment based on this video:
Made a small change to the idle, too.
Definitely more power, and the saw is behaving perfectly. I should have done this years ago. I used to think maybe I should have bought a bigger saw. Not any more.
I have a MS250 and a 440 Magnum. Both are good saws but are monsters to get started. The 440 Magnum was the worst and I would often turn myself into a blue froth pulling on the cord. They have allways been hard to start and I just thought that was the nature of the beast. So I took your advice and opened up the muffler exhaust ports. So now they both started on the first pull using last years gas and they ran like a champ. Your thread was my motivation to do this and I can only say thank you for the instructions. I should have done this years ago. David
