Seeking info on a double barrel (30 inside 55) stove
Any news?
Hows the progress?. I've been thinking about the clips you welded on to the cast door. Cast doesnt weld very well. It might be better to bolt those on. Dont want to see that glass slide down and burn up your shed. I was looking at my pellet stove and the clips are bolted on.
I haven't made it up to the cabin to set it up, had shoulder surgery (torn big head tendon, rotator cuff) and I'm in the middle of putting injector cups in my 02 F 250 7.3 diesel....HOPING it will stop raining in S. Colorado so I can do some trim work and set the stove.....Now I need to come up with the $800 or so for the outside pipe....(15')...Will update as soon as I get up there...rsbhunter
As to the clips, I did use stainless wire on the welder, have really tugged on them, they "seem" secure...am considering running a bead of high temp silicone around the outside of the glass/gasket to help with that situation....
Pouring here as well. Sometimes you can come.across some good deals on double and triple wall stove pipe on Craigslist.
