Flood at startup on oN older (stihl) saw?
ADK_XJ
325
Saratoga Springs, NY
Hey all, coming back to the experts here - I am seeming to run into a flooding issue with my old saw (it's a Stihl 0-41AV "farmboss") when I try to start it up. At least, as best I can tell.
Here's the deal: it ran great on Thursday, Saturday AM I changed out the 16" bar for a 20" (turned it to its side) and went to start - no go. Pulled the plug and it was wet. Made sure I had a spark and even switched spark plugs, but just could not get it going and a good layer of gas/oil mix developed on the muffler.
This seems to happen like once a month. If I pull the spark plug, drain the tank and let it sit overnight it tends to come right back but that's no way to work!
Any ideas out there?
Possibly dirt is holding the needle open causing it to flood
And, for clarification, I use ethanol free and one of those mixing "pitchers" to get the right ratio - when I couldn't get it going at first I used one of those $$ pre-mix cans of stuff you get at the big box stores.
Ok, possible based on conditions - how might I fix? It's done this both Sat and today now.
You can start by cleaning your fuel taank and put a new fuel filter on. I bet you will have to take the carb off and clean it. Also check the needle height.
Ok, know of any good resources or how-to's on this forum or others for doing that? I'm a novice when it comes to more than changing the bar/chain and fluids.
I dont have any tips or tricks. We have the same saw you do, but i have never really messed with it other than putting a new kill switch in it.
Maybe someone else on here will chime in. You can also check youtube to see if there are any videos on it.
Ok, fair enough - we're in the same boat then! :)
I did also just read this great little rundown on "chainsaw wisdom" that I remember skimming when I first joined the forum - I think this bit about fouling spark plugs is what's happening to me:
"With oil gas mixture it is real easy to foul a spark plug. If you have had a hard time starting it after repeated attempts, chances are you flooded the carburetor and fouled the spark plug. Remove the spark plug pull the starter a few times. This flushes out the flooded gas. Replace with new plug and do not choke it down. Try starting with the choke off."
For anyone searching this thread later on you can read the whole piece (it's good, basic, common sense knowledge) here: https://www.hearth.com/econtent/index.php/articles/chainsaw_wisdom
Is this only an issue with a cold saw, or will it happen when warm? By "cold" I mean needing the choke to start. It could be that you are simply missing the "blip" and are choking it beyond its needs. I never pull more than 3 times with the choke on.
Reactions: kevin j
Is this only an issue with a cold saw, or will it happen when warm? By "cold" I mean needing the choke to start. It could be that you are simply missing the "blip" and are chocking it beyond its needs. I never pull more than 3 times with the choke on.
Unfortunately it's happened both ways — cold and warm. What seems to be a guarantee is if I flip it on its side and change out a bar or chain — even if it's been running, that will seem to give it this flood issue.
Hmmm...that does indicate fuel slipping past the carb. 041 is getting some age. It might be wise to just do a carb rebuild. Usually the carb kits are small bucks.
When you clean the carb, change the rubber diaphragms, they get old and hard and will cause you problems.
If it has a Tillotson carb, repair kits are ~$8. New replacement carbs are $20 shipped from China or $26 shipped from USA. I'm ~50% joy rebuilding carbs - if the differential between new carb and kit is $10-$15 or less, I normally just buy a new carb. Search ebay.
Although first, I'll try a no cost repair - clean carb screen, check needle lever height, pull needle and inspect tip - clean tip, soak metering diaphragm in brake fluid (it can make it more pliable), pull Hi-Lo screws and clean with carb cleaner.
Reactions: ADK_XJ
Okay, so sounds like some form of carb cleaning / rebuild is in the works. I have to say, up until this last 12-18 months I was never a very handy person with machines (computers, I'm your guy) but with help from places online like this one and a decent workbench/tools I'm getting there...however, is there anywhere on Hearth.com or elsewhere I can find a good (I'm talking step-by-step) guide for disassembly of this thing?
Back on the ranch, I decided to go get a second opinion at the Stihl dealer near my work because the guy near my house laughed at me when I hauled in my old 041AV and said "i won't work on antiques." This other shop gave me the reaction I was hoping for: "That's a really good saw, you won't easily/cheaply replace it — we'll gladly work on it for you."
They were very up-front but then said depending on the issue I could be looking at $60-80 in repair. Maybe I should try the carb clean/replace on my own first?
You can google "Chainsaw carb repair". Eg. Here is one by donyboy73.
Reactions: ADK_XJ
Perfect. Man, you can google just about anything and make it happen, I guess. Next I'll try "find a million dollars."
So, the saw ran fine the first part of this evening - after refilling with mix, it ran hard and stuttering. It had very little power with a freshly sharpened chain (and cutting a downed pine) and would almost "break up" at full throttle and choke out.
I've definitely got some cleaning up to do with this thing.
New carbs are easy and cheap to switch out. If you have never taken a tiny carb apart, I would not recommend changing just the interior gaskets/baffles. I've done it and there are a lot of very tiny parts that need precise adjustments. Almost always, there will be sawdust that got into the carb and is sticking the needle or one of the ports. If you buy a new one, take the old one apart and clean with gas and have it ready to switch out sometime in the future.
Your last post sounds more like sawdust in the carb. Take the air filter off and pull it apart and make sure it is clean. You may just need to adjust your HL settings.
Yeah? Ok - will do. So, does the quote of $60-80 for a repair at the shop see, ludicrous for the amount of work to do a carb repair DIY style?
Edit: "seem" not see - damn, iPad!
As Doug&3 says, you can buy a new carb for cheap. They are VERY easy to switch. I like HL Supply for parts.
http://www.hlsproparts.com/SearchResults.asp?Search=stihl carb&Submit=
Ok, so I decided to go ahead and grab a carb kit and take this baby at least that far apart.
One thing I am wondering is if my startup routine is causing the initial flood. I thought you were supposed to click on the throttle lock first and do a couple pulls with the choke down - but I just watched another of the previously mentioned "Donyboy73" videos where he starts the same saw without using the throttle lock at all. My question is, should I not engage the throttle lock until AFTER I've done a couple choked pulls?
I'll be feeling real dumb if that's the case and I'll have a clear culprit for my fouled plugs...
On both my 026s, on a cold start I always put the choke on full, pull 2 to 3 times and almost always hear it 'blip' which I would call more of a blurp, then adjust the choke to off, then pull once or twice and it should start. When re-filling the tanks, I usually don't even put the saw on choke, just pull and it's fine.
This sounds easy but it does take some amount of knowing your saw and both listening for and feeling what is going on. I think all of us have experienced some real problems in getting any chainsaw started and almost always it's bad gas, fouled plugs, fouled carb or flooded. You could also have problems with a bad gas line, bad plug, etc but these normally won't allow the saw to run at all or at least run properly at all.
If you want to take it in for service, then it may be worth it for you to stick around and watch what the tech does. Sometimes I get really exasperated and I would rather spend the $$ and get the trees cut than spend a few hours fiddling with the saw.
Right. So, do you do that start routine with the throttle lock on, though? Or does the 026 not have one?
I'm with you. I've got a pile of giant pine sections taken down by a crew last week right next to the house and I'd rather be running the saw than tinkering with it at the moment. However, I am a big fan of the whole "teach a man to fish" principle so I like your idea of sticking around to watch the repair. Either way, the pile of pine ain't shrinking on its own and my wife is starting to think we should have paid to have the crew remove them...pssssh!
