Split em or leave em?
morpho
95
canada
Hey folks,
So I have an over abundance of wood, and I am wondering if it's better to leave them in rounds or split em. I have no room in the shed for any more so it will be outside in the elements. It's pretty dry already and I probably won't be burning this stuff for 3-4 years.
Advice?
Thanks.
Split it and get it off the ground. If you don't split it, try to get the rounds off the ground too. Would be a shame to let it rot - Which, depending on what type of wood it is, may happen in 4 years.
Reactions: 1kzwoman
Yep. I've got some Hedge that is still in rounds, 4 yrs later. It will never rot. If it was something more susceptible to rot, I would split, stack off the ground, and top-cover. Oak or Hickory sapwood goes bad quick but the heart holds up pretty well.
Reactions: kjahnz
Either split it or peel the bark off at the absolute minimum slice a couple of wide channels through the bark . ( like making two flats with a saw ) Bark holds moisture in .
Stack it off the ground and top cover it. Split it only if it needs to be smaller to fit in the stove.
I knew I'd get responses quickly here!
Thanks everyone.
It is off the ground on pallets.
Poplar and Aspen
It's also in really short lengths (10"-12") as I have a wee little stove, so it dries super fast.
This was my first winter with a stove and last summer I lucked into a friend who was clearing some spruce that were too close to his house. I ended up with about 3 cords. I bucked and split it all...and knowing less than nothing, I was concerned I wouldn't have enough to last the winter. In the fall, another neighbour had a bunch of Poplar that he wanted gone and he said I could have. SURE! ...It's like asking somebody if they want free gas. How can you say no?
Well, spring rolls around and I take stock of my still massive stack of splits. I couldn't have burned more than a face cord. AND I still have all the poplar rounds sitting there...another cord and a bit maybe.
I burnt every day last winter in a sub arctic climate. So lets here it for small, super insulated houses and Morso!
...Had another neighbour ask if I wanted some spruce tress that came down in his yard this spring...and another wanted to make sure I knew I could go back into his place and take any deadfall I want to take on his 3 sections of land.
It's like an addiction!
I think I might keep the windows open all winter and burn burn burn!
I always try to get it split right away. There is no down side to splitting it earlier vs later.
so, keep it off the ground and reasonable protected and hope for the best seems to be the major theme. Split it when I get a chance or leave it...one way or the other isn't going to make too much of a difference (except the moisture retention the bark may create.)
Ok...I will deal with it one way or another....sooner than later.
Thanks everyone!
(I see a beaver brought down a birch over by the cemetery...might have to add that to my collection! I can't help myself!)
Ok you're egging us on on this one...... Definitely split the birch or it will go to punk in no time flat! Nice not to have a limit on free wood eh? You and I are in a lucky club!
Split it ASAP. Even if you only split it in half to save time now, then split it more later on. Split wood dries better and lasts longer than rounds.
