Regency U32 Convert back to NG
Rwpeller
5
MA
Hello. I recently picked up a 2003 Regency U32 gas insert that had been converted from NG to LP. I need to convert the stove back to NG, but not positive of the parts I need. I know I will need a new pilot assembly as well as a gas orifice, but not sure about a new valve. Looking at the paperwork of the previous owner it looks like it was converted using a conversion kit with part number 402-969. Also should I do the conversion and then have it inspected by a certified gas fitter or should I see if he would convert it while running my new gas line? Sorry I am new to all this and just looking for help and advise. Thanks.
The LP to NG conversion kit should be listed in the owner's manual.
If you don't have the manual, it should be available on-line at www.regency-fire.com...
Check with your local Regency Hearth Products dealer, or call Best Fire in Green Island NY @ 518.687.2388
If BF doesn't have the kit, they will be able to tell you the number for it, if you couldn't find it on-line.
Basically, you will need a new regulator head, a pilot orifice, a burner orifice, a conversion sticker & the amount
of opening to set the air shutter (which is in your manual, as well)
If you don't feel confident with your technical skills, look for a local NFI Certified Gas Tech. He will have all
the tools & know how to convert your unit properly.
HTH.
HTH.
Thanks for the help. The manual does list the NG to LP conversion kit, but I can't seem to find the LP to NG conversion kit number anywhere in the manual. I will contact the local Regency dealer and see if they can provide me with a LP to NG kit part number and if not I will call the number you listed. I appreciate the help and will let you know how I make out. Thanks again.
Make sure you have the entire model number when you call the dealer. U32-NG?. Insert a number where I put the question mark. They varied some and used different kits. The newer units will also require removing a intake air shield to go back to natural gas.
Thanks for that! The entire model number is U32-NG2. I did get a response from the dealer and I ordered the following:
910-346 Robertshaw regulator
904-240 # 37 burner orifice
910-036 Novasit pilot orifice
904-529 5/32" Allen key
908-529 Yellow NG decal
908-514 Conversion decal
Hope this helps other people as well. Thanks for the help; much appreciated!
I should of added that I agree with DAKSY 110% about having a tech do your conversion. He has the tools and training to do this correct. I always cringe a bit when people order conversion parts. Often receive follow up calls for soot issues. NFI is nice to see and I endorse it but experience wins the day.
I did a search for an NFI certified fitter in my area and needless to say the one close place wasn't a regency dealer so he hardly said a word to me. The next company, which is actual Best Fire recommended by DAKSY, is way too far away. With that being said, will the gas company or certified gas plumber I have running my gas line convert the Stove; anyone have experience with that? I might also convert it myself and have the gas plumber leak check everything including the stove when he is done running the line and hooking the stove up.
Talk to your plumber & find out if he's comfortable doing it. It isn't terribly involved & if he takes his time,
he should be able to do it. Most gas line guys are also certified to work on gas appliances.
Where are you located in Ma?
Will do. I am not too worried about doing it myself as long as everything gets leak tested and such. Western MA on the border of NY and VT.
I agree with DAKSY and would check with your plumber. Not sure about the gas company in your area doing the work. The gas company here does not service at all. Before I became involved in the hearth industry I supervised many mechanical contracting companies and started a mechanical contracting company and at that time the gas company had what was referred to as the ally program and would refer consumers to qualified companies when called for service.
PM me if he won't do it. I've probably done a hundred gas conversions & I'm about 35 miles from North Adams. 30 from Williamstown. I can take a run up there.
Props to DAKSY. What is a Patriot Guard Rider, may I ask ? I researched it. A true patriot. Pleasure to meet you.
