Gnarly Red Oak
Just got around to splitting the base logs of a large red oak that was standing dead for a couple years, then bucked for 2 more years. It's still some very nice wood, but the majority of the base logs (probably would have been the bottom 8' of the tree) were stringy. Worse than any sweet gum I've ever dealt with. Usually the straight grain of the red oak makes it a pleasure to manually split, but these were impossible. So, thank God for the hydraulic splitter. Some of this wood feels like tire rubber. Really weird. It'll cure and burn just fine in a couple years, though.
Most of the base logs were like this throughout:
But this last pic shows how some areas were encapsulated. This is a side-by-side split. The one on the left is domed (convex) and the one of the right is concave. Almost as if you could scoop it out.
As a wood worker go ahead and burn it
To hard to sand
To hard to seal
It is not worth the effort to work with lots of nice oak out there
Just my 5 cents worth have to add 3 cents for the poor Canadian dollar
Reactions: 120inna55
Too bad woodworking is out on that grain. I bet it will burn spectacularly
That is wild looking stuff; looks like wood you'd see on the TV show "Sleepy Hollow"!
I split up some box elder this weekend and the base of that was terribly knotted as well. I didn't have a phone with to snap picks, but I ended up with many crescent shaped pieces of gnarled up garbage. It won't be fun trying to pack a stove full.
That is some weird looking oak for sure.
I wonder if that's the result of coppicing, many years ago. That grain took many years to form, not likely the result of what attacked it in its final years.
Good point. It is deep in the center of the tree. For what it's worth, it was a straight, normal looking tree prior to its death.
You should crop that first pic and make it your avatar. Not that I don't like your current one..._g
Reactions: D8Chumley
Is that tree related to van Gogh?
chazcarr that is too funny. That is the first thing I though of when I saw this wood.
It is amazing how the swirls grow
Reactions: chazcarr
