Need opinions on mini split
You can install either way. Floor mounts also can blow air on the floor and in the air.
So do these floor mount, or low wall mount, units run the coolant and drain lines out the back into the wall or down through the floor?
Either way for the lines. My wall mount and floor mount run down under the floor and through the rafters outside. I did not want to have the lines seen on the outside or in the living area. There mounted on inside walls also. The condensation lines are also ran in the basement to a drain. I the wall mount is installed on a closet wall so the pipes are hidden. A little planning and they are pretty flexible in placing.
Reactions: Highbeam
A friend up north is looking into having mini-splits with the floor units installed. If they go for it I will go up and take pics of the installation.
Reactions: Highbeam
Lines can go down through the floor, out the back, or out the side.
