Tree ID. Many Pics.
SawDawg
52
East TN
Leaf
Underside
Branches are large and grow outward close to ground instead of up.
Branch
I'm thinking hedge apple. Trees are either male or female which means not all trees have the tell tale fruit. It also appears to be in a field line which makes me think hedge.
fv
Maybe Red Mulberry, the leaves are serrated. It has a general look of unfriendliness to being cut down. Or are you just curious?
The identity of this tree has eluded me ever since I purchased the land 20 years ago.
I cut a few rounds from a branch a decade ago, but used the rounds for a campfire so I'm unsure if it's easy to split and can't remember how it burns.
Some of the branches are dying like this one below. I am going to "prune" this tree this winter and get some firewood at the same time. Just trying to figure out what I have while the leaves are still on it for easier identification.
The top one you have your hand holding the limb is mulberry. IF it had a few small thorns on that limb then I would say hedge
I think this is White Mulberry. Red Mulberry doesn't get this large. Maybe it is a male White Mulberry which wouldn't get berries, so you wouldn't have the very obvious ID clue that the berries provide.
No, my best friend has a Red mulberry in her front yard, (granted, its sitting on top of her septic leach field). And its quite girthy.
Red Mulberry has 4 different possible leaf shapes that are usually found on the same specimen (tree). Do you see different leaf shapes or are all the leaves that simple shape?
The reason I ask is that while the tree shape and leaf do look like Red Mulberry, I find it odd that it wouldn't have at least 1 of the other possible leaf shapes...
Going by the tree looks and not just leaves, it's a mulberry of some kind. Once you get it cut and split, it will be warming you again in about three years.
