Do have an electronic or a photos of a pictured manual?
Here is a website for Kent. Really good website they have. It gives the history of Kent and other cool info.There are part #'s for all the new and old stoves. Look under " Information Downloads". My KTF is going strong. Temps here in GA have gone below 0 with wind chill. I just found a different website that sells some spare parts for Kent. Check it out.
"I don't always burn wood, but when I do.... I use a Kent. Stay warm my Friends"
Welcome to a Warm Home - Wood Fires | Gas Fires | Heat Pump Space Heaters
http://www.direct2you.co.nz/147-kent-spare-parts
Wow, I can't believe I missed this thread when I first got my tile fire from a friend 3 years ago. I was wondering about the tiles on the sides. Mine did not come with any tiles, so I just used ceramic tiles. When you started this thread you said the tiles weigh 30lbs?? If that's the case I'm thinking the tiles on the sides are special thick tile? If so, anyone know what I could use, because then I've been using the wrong tiles this whole time.. Thanks for any info!
Peter, as long as your tile are the right size, you're good to go. Any contribution from their heat storage is minimal.
We found the same. We purchased crimson and white to replace the originals. I wondered if you could elaborate on your recommendation for single wall flue to the roof. We bought our TF in 1986 and originally had single wall all the way up to the cap. When that started to get thin, we replaced it with stainless double wall, which was supposed to last longer. The first thing we noticed was a dramatic drop in heat from the stove. Well, the SS flue did really last a bit longer, but it's now hard to clean, particularly at the transition at the roof line, so we're going to replace it. Any advice appreciated.Peter, as long as your tile are the right size, you're good to go. Any contribution from their heat storage is minimal.
Another issue, which I thought deserved another paragraph. In the almost 30 years we've had the stove, about three times, I've had the section of flue above the roof (double wall) clog with creosote extraordinarily quickly. Each time, there has been a cold snap. I cleaned the flue around two weeks ago and the draft started suffering after a cold spell, when the temps got down to about 12F here on our mountaintop, cold, but not nearly as cold as it can become. We are burning a mix of very dry wood and some not as cured as I would like. It is not green. It came from a pignut hickory which had been dead on the stump for about 1 1/2 years. However, I only cut and split it about four months ago. It rings and produces no bubbles on the ends while burning. However, when I went up to clean, the flue top, down to the roof line was completely clogged. The flue was clear below the clog.
Member precaud https://www.hearth.com/talk/members/precaud.482/ is a Kent expert. We have one too and we love it. But I am far from an expert.We bought a house 25 years ago with a Kent Tile Fire that we have enjoyed to the point where we are going to take it with us to another house - in fact I may be buried with this stove! I've done a lot of things wrong over the years (apparently), the damper as always been very difficult to move (vice grips to open, hammer to close), so I have burned 25 years of fires with the damper fully open and then just close it seasonally. After poking around on this site I gather either it is warped or full of ash. So what is the downside of burning with the damper fully open? Loss of efficiency? Also, did not even realize there is a secondary chamber so obviously have never cleaned that out. Since we are moving it would it be insane to just rinse all the ash out after we take it out of the house (as opposed to vacuuming) with a pressure washer? Last - the black enamel finish doesn't fit in the new local - can it be repainted with some of the heat paint available? I've painted woodstoves but they were more of a matte gunmetal type of finish so took paint - no idea if the baked on enamel can be painted.
So I've had this stove for half my life and have really enjoyed it, but now that I'm moving it would love to get some advice from some of you superusers! Thanks!
We bought a home 28 years ago and it came with a Kent Tile Fire. It has served us well over the years but is not heating well any more. The bottom plate of the upper chamber is now badly warped (downward) both at the front below the series of holes and below the flue shut off plate. Is this stove now scrap? Or can it be repaired? If replacement is in order what equivalent stove would be recommended?
Thanks!
Thanks! So you just take the grill off the stove top and sprinkle graphite powder on the visible part of the rod?Member precaud https://www.hearth.com/talk/members/precaud.482/ is a Kent expert. We have one too and we love it. But I am far from an expert.
I lubricate the damper rod with graphite powder every 2 years or so. The best way to clean the interior and the 2nd chamber is when you sweep the liner, remove the stove from its location (disconnect the liner) so you have access for vacuum the entire stove. It is not that heavy.
