So I think I got the burning out thing figured out. I added in a ball valve that can draw air in the bottom and it seemed to keeps the coals got today. I lit the fire this morning at 6 and it was burned down to coals at 5 this afternoon. It was a load of pine lumber scraps.
To answer the questions I do not have a heat dump zone. I was going to use the garage for that if I ever needed to but so far right now it hasn't needed to happen. And my water jacket holds about 120 gallons. No storage this season.
So my initial thoughts are, I'm liking it. I turned the garage up to 65 on the thermostat and it held just fine. It smokes alittle more then I would like while it's idleing, but that should change once the cold weather really sets in since the idle time will be alot less. With the first fire I was heating my pretreatment solution which I had to later drain then refill with fresh treated water. It took the first fire about 1 hour to heat the water to 150 degrees. After draining and refilling and firing again I had to leave for a couple hours. When I came back home the boiler was sitting at 170 degrees and garage was toasty. It's still a learning curve right now but I think I'll get it down.
So here's some pics.
My fill adaptor let's me fill through the over head coils to help push the air out of the system.
One of my pump isolation valves came with a hose adaptor on it too this will help with draining and taking water samples.
I also made up a rain cap for the chimney. I need to make it alittle higher though so it's not on right now, but here's what it looks like.
First load of wood
And The first fire coming to life.
I had some serious condinsation issues in the heat exchanger until my water temp reached 130.
And what was left of the first fire
The second fire at night.
Water vapor coming from chimney while fan is running. It goes up about 5-10 feet then disappears.
And my early Christmas gift from the Father in law
So what's everyone think?
