PP, PEX or PEX-AL-PEX for Geothermal?
Not a lot of geothermal discussion on this board. Hence your lack of responses I suspect. Don't take it personally...
What type of polyethylene pipes would best for underground loops? and what sizes?
Any thoughts?
Go with the tube built for specifically GEO ground loops.. They will be cut to the proper length and have the return bends fused on, typically. PP is the most common material. The size of the tube you select depends on how much flow (energy) you are trying to move in and out of the ground. Typically 3/4 - 1" for residential 2" or larger for high load fields.
If it is a ground loop system best to consult with a GEO "looper" that is familiar with soil conditions in your area. Also the heat pump manufacturer should be involved in the loop field design.
Interesting way to document a loop field with a drone camera, from a installer in WI.
