My ash solution for the Jotul F55 (pic heavy)
It looks like a nice design, but like Grisu said, taking out so many hot coals isn't typical for most folks who are removing some ash from their stoves. I would never try to empty ashes from stove with as many hot coals as you show in your photo. Maybe you don't either and just had them in your photos. One thing I would be very careful of with your system is that you don't slip or bump something on you way out of the house with that hopper filled with hot coals and ash. The lip that goes over the back edge of your dustpan looks like it could come dislodged pretty easy if you slipped. I know when I am emptying my ash pan I'm always very cautious when carrying a pan filled with hot ashes as I go down a set of carpeted steps.
I was thinking the same thing.....one slip, and OMG !!. I know even with our Ash Bucket, it's always on my mind.
Good Job, I use a smaller shovel and scoop into a Metal bucket with a lid, when done it goes to front porch to cool...
Never, never, leave the bucket on the Front Porch !!!....if it's a wood floor. Had a friend leave his bucket on his deck.....woke the next morning to a burned out hole in his deck with the bucket just under it.....burned right thru.....and be sure the top is secured so a gust doesn't blow it off.
Ditto. Saw a house burn down from this two years ago. Seen another two consumed by a vacuum in a closet, after vacuuming up around the stove.
Ash buckets and ash vacuum are kept on flagstone patio.
I like this contraption! I haven't perfected a method for raking the coals forward and removing only the ashes. I do my best with the fireplace tools that we have. When i need to get a big load of ashes out, I use a metal landscaping shovel that takes out about 90% of what is in the firebox in one shot. I have a small kitchen garbage bag all ready to go at the opening of the stove and slide the shovel into that. This is only done on a cold stove after i have made sure there are no hot coals in the box.
Just a word of warning - ashes can contain hot coals for up to several days! Don't ask me how I know this! Best practice is to always put your ashes into a metal bucket with a metal lid. Believe me, it is much better to be safe than sorry.
I have no ash pan on my stove either. The simplest solution I've found is to burn down all the coals to ash and let the stove burn out. Then I scoop them into bucket and carry them outside. Restart the fire and I'm good for another 2 weeks.
Yep - exactly
Id pay good money form ash vaccuum that i can stick into my stove to get ash out while coals are hot.
Most don't want a vacuumed-clean stove during the burning season.best to keep at least an inch of ash in most stoves.
When raking the coals, ash naturally filters to bottom and coals rise to the top. So, just push those coals aside, scoop out some ash, and then redistribute what you're leaving evenly across the floor of the firebox.
You'll save fuel if you keep your embers and you won't have a fire hazard with hot embers in a can. Take a look at this ember and ash separator or this one. It is also nice not to have to let your fire burn out in order to remove the ashes.
