Mini-split heat pump question
Nickel
1
Southern Vermont
Installed a Daiken mini-split heat pump this summer. Has been a warm winter. When the heat pump gets the room up to temperature, but not the whole house, it will shut off for less than a minute then come on for less than a minute and continues to do this until I get tired of listening to it and shut it off. I e-mailed Daiken over a month ago and never heard back, the plumber has disappeared and Efficiency Vermont says that is what heat pumps do. I hope not. Is this "short cycling" normal? Any suggestions as to what may be wrong?
My mitsu unit doesn't do that.
In all, I wouldn't be happy with how that unit is running either, but I do not know how the Daiken units are programmed to run. Maybe that is normal for them.
Any way to check for error codes on the unit? Mine has a side cover on the outdoor unit that comes off with a list of what to look at with an LED bulb.
pen
Often there is a setting to control the temp swing. See if you can get hold of the service manual for the system.
... Is this "short cycling" normal? Any suggestions as to what may be wrong?
Shot cycling is not normal.. the new heat pumps have a variable speed compressor that spins up and down as needed
Perhaps it is just the fan in the room heat exchanger that is cycling.
Hmmm - if the heat pump was installed by a plumber, that might be part of a problem.
There must be someone else selling & servicing Daikin around there that could check it out?
