One two wheeled dolly helps, to roll it out the door and down ramps. I rolled my coal stove out and the P61 in that way. It still took two people to get the dolly tipped back and stabilize the stove even though I strapped it.My son (16 & 180 lbs) and myself can lift the unit off our hearth and set it on the floor. They are pretty heavy. You need two strong guys to lift it..
Hi Scott. Thank you for your kind offer. I was to go pick it up on tues. they had someone lined up to buy it but they backed out and they called me to say the stove was mine if I was still interested. So I postponed the job I had lined up for the next day and put ramps and dolly in the truck. Text her the next morning to say I would be there in an hour and she tells me "too late it's sold". I tried calling her and never answered the phone. So bummed. Ty all for your input.Bring two 24" long 2x4's to slide under the rack and slide out the unit so you don't damage the hearth extension. Disassemble the sayings to remove the weight. Disconnect room temp sensor from blue wires and disconnect brown, white and green from power outlet before extracting the unit. Once you get the insert out on a dolly, the rack disassembles. You can remove the 3 rack castings to lower the weight of the rack. If you haven't got it yet, you can use my lift corkman.
so this deal has been reurrected.seller contacted me yesterday to see if i was still interested.she was all in a jumble and apologised for the mix up.she apparently didnt realise i was the one she had agreed with to buy the stove and was wondering why i hadnt contacted her.the weather today had me sitting at home so off i went to see it.i pick it up tomorrowYeah that's the thing with used Harmans, gotta go that minute and have the funds.
Yes the hopper lid is back on as is the door. My mechanic drilled out those 2studs and last night I installed the auger motor and combustion blower with a new fan blade. Just about ready to be fired up if the weather cooperates. It's in my shed so I gotta pull it outside once I get a chance to burnDid you put the hopper lid back on? If that lid is off or open the feed motor will not start. Does the comb. motor turn freely. The vac switch has to close for the auger and the igniter to start. vac switch opens and closes the neutral to those 2 items. That is why you get the light even if it does not come on.
