New RSF Delta model
I saw this in person this spring, it looks great. I was impressed with how clean the glass stayed compared to the older unit. My rep is telling me that i should have access to the new units some time in august
The Delta 2 model is already a serious heater. I'm assuming that the hybrid is a tube + cat design. Is that correct? If yes, how well have they located and protected the cat? How does it look for servicing the cat? If not, what are they using?
Thanks for your info BeGreen!
It's always great to see new zero-clearance fireplaces introduced to the market. It looks like a real beast. I wonder if at some point RSF intends to add a smaller version...
Matt
It isn't a catalytic unit, so it should be really easy to service ;-)
Thanks for clearing that up. The specs are impressive for a 4.4 cu ft non-cat!
Got word from RSF on the fireplace. Brochure attached. It has a somewhat odd configuration. The air supply is controlled by a bi-metallic strip. No user control except by load size.
  • RSF_Delta_Fusion_Handout.pdf
Sorry i didn't get back on quicker. Yes the unit is tubes only and has no air input control. They have adapted the bi-metallic system to stop over-fire in the old system, and now use it to control all air input. In doing this they fall into a different testing label and if i remember right only have to do the high limit test instead of averaging out the low and high test.
The other beauty of the bi-metallic system is that it keeps the fire at the high end and keeps allot of heat in the sysem, end result is the glass stay cleaner for longer and still if able to pull down some decent burn time numbers.
Of course this is all coming for sales reps and no dealers i know have one in the field yet, so this winter will be interesting to see how it reacts
The Delta 2 really puts out the heat. At HPBA the strong radiant heat was immediately noticeable when compared to the other fireplaces burning.
I installed the Delta Fusion fireplace last fall and used it 24/7 all winter and the heat is unreal. My house is 1500 sg ft with a 4 ft crawl space and I have a fan taking the heat from the fireplace and heating the crawl space also.The problem I have is the glass gets black really fast. I live in Newfoundland Canada and we don’t have a lot of hardwood so I use well seasoned fir. It also goes through wood faster when it is really windy outside.
Reactions: begreen
