who using a FISHER BABY BEAR ?? maybe even in/on a fireplace hearth??
trx680
101
Petersburg Virginia
I'm looking to put a wood stove in/on my fireplace hearth. Biggest problem I'm having is finding a stove that isnt too tall. The height dimension is only 26 1/4" tall in my fireplace. My house is 1200 sq ft. But I dont want some stove with a tiny firebox.
I've seen where people have cut the legs shorter on the Fisher stoves to make them fit in the fireplaces.
I had a Century insert I picked up at Northern a few years back but I just wasnt impressed with it. Very small firebox and fire didnt last long.
These Baby Bears have some room in the firebox which I like. And I grew up as a kid heating the house with a Papa Bear in the 70's. Mom still uses that stove today.
Just wondering if anyone uses a Baby Bear in their fireplace that can give some input on how they like it or and recommendations.
Do you have a liner in the chimney already from the insert? If not what ever you do you will need a liner installed in the chimney to make any stove work correctly and safely. Baby bears are pretty small to I would not expect to long of burn times out of one.
I have a Huntsman that is very close in size to a Mama Bear. The legs were removable and I removed the rear legs and put it partially on the hearth with a stainless tee into a 6" liner. I am pleased with performance.
Pics are on thread titled "ASW Huntsman"
Forgot to add I did make a block off plate using sheet metal and Roxul where the liner passed through the damper. A Fisher would be a good choice...if I ever change out the Huntsman it will be for a Fisher.
Not sure why you wouldn't want an Insert? There are full size and smaller Inserts (Honey or Cub) available as well as glass models for fire viewing in the fireplace. A blower extracts the heat from the back and radiates forward from the section that protrudes from the hearth for power outages or cook top. There is much less heat radiated into masonry which rises out the roof as well as out the back if you have an exterior chimney. You want to heat the air, not masonry in most cases.
Baby Bear may be too small for your heating requirements, has a very small firebox and it's not good for the stove setting back into the hearth restricting air flow around it. The Bear Series stoves (Papa, Mama and Baby) are maximum 24 5/16 high and lower in the back with legs cut to set directly on hearth.
I can give you the measurements (height) of each model as well as the height of the rear flue outlet. Measurement would be from drawings or rear sheet sizes (box without legs) since fabricators vary leg length. I can only tell you what they are supposed to be.
The single door stoves were first designed with your installation in mind. (Inserts were designed in 1979) Single door stoves were available with left or right side vent to place the stove sideways on the hearth to protrude less into the room and still radiate in all directions. In that case you want a left or right Mama Bear depending on which way your stove faces. Insulation should be taken into account sizing the stove since in your area a well insulated house would be fine with a Baby, and possibly overheated with a Mama. Many other factors should be considered sizing the stove.
One last caution since you're still exploring the options of installing a stove within a hearth is maintaining a minimum 3 inch clearance for air flow. There were isolated incidents of uneven heating causing cracks when installed in this manner.
Post #10 in thread below is the builder / welder from Fisher Stoves S.E. in reference to your type of installation.
https://www.hearth.com/talk/threads/new-to-woodstove-heating-fisher-papa-bear.71552/#post-902932
A blower pushing air under the stove, up the back and out over the top helps maintain even cooling.
