Englander top auger
Amyelove
1
Mt storm wv
I need help my englander pellet stove top auger keeps stopping ..the vac system has been deleted long ago and worked fine
If this stove has (2) auger motors, switch the lower auger with the upper auger, to see if the problem follows the augers. If so, now your bottom auger will be acting up. If it does, you have a bad auger. replace the one that is stopping. If problem still stays with the upper auger after switching, atleast you narrowed out that it is not auger motor related. you need to look else where like bearings and or auger out of alinement. It could be a deeper issue like main board. Atleast see if the problem follows your switch around, to know where to go from there.
just saw this post and not sure if you figured it out. Is it stoping or is it jamming? The top auger is supposed to stop, that is how it regulates the feeding of the pellets.
