How often do you clean your chimney?
eba1225
312
Chester Springs, Pa
I have been experiencing a harder and harder time in getting a good roaring fire going. :-S I first thought that it was due to the wood, but ruled that out when I used 'different' wood and still had the same problem. My fire with the doors open about an inch burns good, not great, but not as good as I remember it did when the the stove was first started. :grrr:
I have summized that probably the chimney and or the cap have a buildup of soot or is partially plugged.
I have not cleaned the chimney/liner since it was installed in Oct. and it has been running pretty much 24/7 since then and at a low air setting.
I plan on sweeping/cleaning it this evening.
My question to you guys is how often do you sweep your liner?
Erik
At the beginning of the season, at least once during the season (weather permitting access to the roof), and at the end of the season...
Used to do it 4 times per year. Since getting the Fireview we have not cleaned it once and have been burning 24/7 since October.
The last time I cleaned my chimney was after a season of burning about 8 cords three years ago. 1.5 cups of white dust was the sum total removed from the 21 foot chimney. With the stove burning that clean, I don't clean my chimney.
Once, in the Summer, on a nice day.
I used to, however, inspect it more often in the Winter.
But then, I sorta had to.
My chimney had to come down last Spring before it fell on someone / something.
Leaning tower of Pisa. When the last anchor popped, it wasn't safe any more.
Brick / lined chimney. Outside.
We won't discuss what it looked like for awhile, nor define "for a while".
It was a surprisingly good functional chimney, it had just become the i in team.
I was going to put in a pellet stove, but found it a tough transition.
100% oil is tougher.
"Hey, I bet on a windy day you could crack nuts with that chimney".
I heard them all.
For a while thear I was once a week!!!! :down: I am at 2 weeks now and don't see any need! LOL Hopeing to go the rest of the season! But I was burning cool and bad wood as well.
so many variables. I burned by stove for 1.5 years without cleaning it. I jsut cleaned it a few weeks ago cause I was also getting some puff backs and figured that it was definatly past due..The cap was the worse and my guess contributed the most to the decreased draft, but I cleaned the entire thing..was not that hard to do actually
I am a afraid of heights.
I call the chimney sweep once a year before the season starts.
Once per year, usually in the early Fall before the start of heating season. Been doing this for 18 years. I have very little build-up in my chimney, burn dry wood, mostly aspen, a little oak, birch and ash.
Late Dec. or early Jan. and then in May.
Just bought my own brush and rods, so going to be twice a year now. Only got a 5" dia. liner with a 20ft draw,so doesn`t take much cresote to affect things. If, and that is a big IF I keep on aging, maybe I will just do the summer clean and have the chimney sweep do the winter one.
Of course there is always "liquid courage" for the winter one. but probably not a wise choice when 20ft off the ground :)
Are you telling me people would actually climb up on a roof sober? No way man!
Every two months. I don't get much from the chimney, but I do get some buildup on the single wall.
Matt
I cut a 3 ft x 4 ft hole in the roof last summer because my chimney up 48 feet high & no other sane way to get up there. Then I had to make a hatch cover to plug up the hole,
%-P because by oct them nites were starting to get chilly & that hole made quite a draft.
So now, to clean my chimney, all I have to do is walk up the attic stairs & pop the hatch
& im good to drop the wieghted christmas tree top down the chimney & pull it back up .
I have ropes on both sides of the christmas tree top just in case it gets stuck in the chimney.
once in the late fall & again in the spring. I aint going up there with ice or snow on the roof,
its 40 ft straight down. I probably shiver so hard from the cold winds that the shivering alone make me fall. A frame roof anyways, steep & dangerous. Need to straddle the peak.
You cut a hole in your roof so that you could use a christmas tree top to clean clean your chimney? Surely you jest.
Usually do it in January and again at the end of the season. At that time I add a wire mesh to the cap to keep the birds out. So 2x works for me.
Once a year here in early fall..
Ray
Not as often as I'd like to. Say- I did a cleaning yesterday evening, and the cap was caked pretty good. On cleaning it, I found a diamond mesh surrounding the cap breather sides. It was secured with bailing wire which I thought the previous owner put on so I removed for cleaning the cap, I wonder though if it might be prudent to leave it on as to catch embers as I did not reattach it thinking it would cause obstruction. I did see a small one stray out last night. I was rinning 500* in the box 300* in the flue..............
All depends on the quality of the wood. We usually have it cleaned by the local sweep in late February. I like having him give it a thorough inspection for damage, kinks, potential problems, whatever. This was a bad wood year. Next year our stock will be back to normal.
Update,
Cleaned it Friday evening. When I took off the cap I was amazed, looked like about 1/4 - 1/2 in of soot/creosote on the liner. Came off very easy with the nylon brush. I figure that I brushed out a gallons worth of soot.
The caps holes were at about 50% with again what looked like creosote/soot, which came off easily with a brush.
I attribit it to doing a lot (>75%) of burning with the draft on low.
Well now I know a cleaning at the end of the season and then again the first warm spell after Christmas.
Thanks for all of your words of wisdom.......and no I will not cut a hatch in my roof.
Erik
