Mike from Athens said:I guess I really need a good reason to justify an extra $1000 in price.
Do I understand you to say that your Defiant stoves actually DID burn wood? :lol: I've spent this whole winter with soapstone and you're right, it's a completely different rhythm of burning you have to get in to. I'm still learning but have reached a point where it just fits in fine. House is ALWAYS comfortable, but I always load it in such a way, depending on whatever weather conditions, that it is that way. Like you say, no quick pop from soapstone, so you let it cool and you pay for it. Sure that's true of even a behemoth like the Equinox.swestall said:As you guys know, I got the Mansfield instead of the T=6. I don't regret that but I also don't think I'd have regretted the T-6. The Equinox is a big momma for sure; my house is 2400 sq/ft plus a lot of Cu/Ft to boot. I originally was going to get the Equinox but I thought that it would be a bit of overkill since the Mansfield was rated at 70K/BTU. Also, the way my stove sits on the Hearth I would not be able to make use of the side door and didn't want to change my set up.
The Mansfield is doing a good job. I have pretty good burns overnight from 10PM to 6AM. I do damp down all the way. In the AM my stovetop is about 250 and the house is cooling; but I expected that. Next year, I'm going to try an in pipe damper and see if it slows the burn down and retains a bit more heat. I am 16 feet stack of 6 inch stainless.
The big question for Mike is will you really be patient enough to wait for the soapstone and do you have the time to keep it up to temp. That is the one drawback with the soapstone as I see; you don't get the quick pop from it. I'm working around that, you may or may not want to.
No doubt the Equinox is a great stove. If they had one in stock I might have gotten it anyway; but I am happy with the Mansfield and think my wood use has been reduced by 1/2 from the Defiant stoves (CAT and Non-CAT)
I wish I could put in the T-6 and evaluate the difference as I would really like to see which does the best job.
In this case I think its like deciding between the Rolls or the Bentley!
HB, really well put. More than once I based my decision on what I was experiencing now only to regret it a couple of hours down the road.Highbeam said:That rhythm is different than steel. I was sitting in my living room with guests last night and the room was a nice 75 degrees and low 40s outside. The stove top was cooling into the 250-300 range and I went and stoked my heritage up with a medium load. The guests thought that I was crazy(er) since it was already quite warm but We all sat there and watched the roaring firebox slowly warm the stove up but not the room. The lesson I had to teach them was anticipation. With the soapstone I had to anticipate the room cooling off and start the warming process early to prevent it.
Highbeam said:Well a bigger rock (the equinox) at 200 will make more heat than the smaller heritage. If the stove had twice as much surface area then it seems logical to expect twice as much heat output for a given temperature.
I just wonder if the T6 will hold the heat
