Can you duct you hot wood furnace air into your LP furnace cold air intake as long as you make it so the fan on LP runs when the wood furnace runs?
brooktrout said:Sure. But by the time the air goes through the ductwork, the plenum and out the supply registers, it will be cold again.
I heated my house that way for 10 years. It worked quite well, all I had was a Papa Bear Fisher stove and an open cold air return above it. It kept the house very nice, I just ran my furnace blower all the time. The only part we didn’t like was the mess and smoke puffs when filling in the house. It is really very simple.
BeGreen said:As far as tying it into the existing system, it is designed to be installed next to the furnace. I don't understand why on earth it would be installed on the floor above it. That is just wrong.
LEES WOOD-CO said:Why not just run HOT into HOT. I have a tri-level and it works fine. Stove being on the lowest level which is about 5' below highest level. No basement.
huntingbuck101 said:BeGreen said:As far as tying it into the existing system, it is designed to be installed next to the furnace. I don't understand why on earth it would be installed on the floor above it. That is just wrong.
I have a 12x26 ground floor room betwwen the house and the grage that I would like to use as a furnace room. It would keep the mess out of the house, and could store wood and it's gound level so no halling wood through the house and down to the basement.
