CENTRAL BOILER. bypassing my h/e had a few questions
adamant
58
central boiler has green poly pex pipe with a thick wall that they used to run in my basement. i need to make up a by pass line with pex and i cant find that heavy wall green pipe just regular pex . will that regular pex be fine? also giving those shark-bite fittings a try..
what i planing on doing is just kill the power to the water circulating pump in the morning before i go to work and by the time i get home it should be cool enough to cut the pipe and work with it.
any other suggestions or pointers are welcome.
thanks ant.
tagged valves
picture of valve tag refference sheet
I don't think you would have any problems with any oxygen barrier pex pipe- but why don't you just buy the green pex and fittings from your CB Dealer ? It would make it easier to match up with what you have. It's sometimes a hassle mixing different PEXs / Fittings.
Have to say that the pluming in the pictures is a little messy.
i only needed 5' of pex. my dealer is about 150 miles away round trip. that white pex is the same as the green pex the dealer installed.
if i went with the pex fittings i would have to get the crimper. the shark-bites you see in the picture is something new. they work well and easy to install.
little messy did my best to retro fit in a existing system.
post pictures of your install :question: :smirk:
SORRY I said that- none of my business. :red:
Mine is a radient in slab- cant take pictures.
Almost any plumming supply house should have several PEXs that will work.
Again- Sorry !
