Harmon Pellet boiler
Let me start by saying I appreciate your answers...their biting thoroughness.
I hope you might see some humor too!
As for the lack of that tinkering inflamation, I am willing to learn.
Good - your on the path
My heat loss is in the 50000btu range. At 100BTU I could go from -20 up to 80 degrees (at least in theory).
OK now let play! Baby Boiler can work this load.
I read your discussion with brown. Your piping my be fine. But my second zone (150 foot loop) was being circ. by 007. The head loss in the pex loop was insane and the pump was not doing the trick. My wonderful plumber turns up boiler temp and goes with larger nozzle and I was able to get by. It was at that point I realized I needed to learn. Your conv. if nothing else reinforced my problem. So though it seemed frustrating, it re-confirmed work that I will need to get done while piping my new boiler (whatever that may be). I currently run a system 2000 oil fired boiler (beckett burner) and burn 1050 g a year. I hope this translates into 8-10 tons (I get approx 9 when I do the math, but theory concerns me.)
It appears common to me that a Plumbers solution for a cold room is simply turn up the heat on the boiler and send greater energy bearing liquid to the load - this equates to higher operational cost for the load and a less comfortable room. We can fix that by balancing the load - but that come later.
With all that being said, I have a question I do not know you can answer: What is your take on the Harman? Any concerns or questions you would ask a dealer? I have 2 local options (amaizing heat and harman)...
All these options are fine options - its like asking should I buy a Ford - a Dodge - or a Chevy - after all won't each get you back and forth to the grocery store??? Harmon is a little ahead in the curve on the technology that controls the boiler. I think the feed system works well - everyone says the resistance pellet auto lighting sucks - propane auto lighting seams the way to go but that is only in outhouse pellet boilers or far bigger engines. So the auto light feature of the Harmon is not a feature I covet! On the flip side with out auto light - now you idle the boiler till there is a call for heat from the load and that takes a couple pounds of fuel an hour... cost of fuel vs cost of resistance energy and replacing resistance elements --- wash - Maybe??? I like a standing flame and hot boiler to reduce the thermal cycling on the vessel. Amazing often doesn't eat straight pellets well and never dirty or dusty fuel - i have mixed saw dust into my pellets trying to clog the Traeger fed system and it kept up like the Energizer bunny!!! I think Harmon is off the table with the back order drama - Amazing - is a good machine but it looks like a water heater and thats what the base design was - from an old dry cleaner system of heating water. And I think their dealer network is a bunch of Amway salesman but opps too far again... sorry - Maybe Traeger is overbooked too by now - they are after all making grills for summer hehehe - I just can't let that go!
Last questions: I am unclear is the Traeger a fire tube (I thought it was) and I believe the Harman is... am I right, and is this good or bad, or just does not matter?
Traeger is a cheep design - not very efficient - vertical tube single pass vessel fire tube boiler. But the fire tubes are orientated and the appliance is built so the tubes are easily cleaned. Harmon is a water tube boiler - opps they like to call them selves a water wall boiler - same business - to clean it you have to GET IN there and its no Picnic. For that there is a better transfer efficiency - but that can easily be lost if you don't clean - and no one does because its a pain. Wait some one will tell you otherwise in a New York minute - ask you dealer about that maybe and see what BS you get. Traeger has the pot fit drama - you have to stand on your head - pivot on your elbow - and slip the heavy pot up onto the feed manifold when you remove and replace it for cleaning - no body is perfect - you have to pick something and deal with the short coming - hopefully you will be happy with the good features. If burning straight pellets - I made a couple of tools so I no longer have to R?R the pot - I also changed the pot a bit and get a better Delta T.
Your air handlers can be balanced to the load - then the out put of the boiler can be portioned to each loop.
Thats the opposite of how a plumber would set up the system. But I find myself again skating on thin ice casting dispersions at plumbers so I may as well head for the deep end.
What did the heat loss calculation predict for a water temperature (heat exchanger temperature) necessary to carry each loop load at -20???
If you can afford a BAXI (H S TARM) - if you can find one - buy it - all the above is mute.
Great info. Much appreciated...
My delta t refers to my return temp vs. supply in loop. I say that b/c is there a different one with regard to a boiler; I have limited knowledge and am trying to learn. Me teach English, so I learn as I go That number is based on coil specs. 180 degree water at 1000cfm (flow rate of 6gpm) returns 157. Is that what you are asking? Should I be concerned concerned? That is putting out about 70000 BTU per coil.
Based on your info, (Tarm out of my budget) I have a little more "soul searching" but I am leaning on the Harman, local and sounds like it will meet expectations: be warm, go green and save $. Any last suggestions; warnings etc...
Again Thanks!
I am the only owner of a PB 105 in my province, so my service guys have no previous experience to draw on, Harmon will only respond to their authorized service people, not me, the consumer, although I will try again soon. I really think the little clean out door with the thumbscrews above the igniter is a bad idea. They tell you in the manual it only needs cleaning once a season, but I think that's not the case. I'll keep you posted.
Hey Alaz, One thing I cam tell you , besides the igniter issue is the 105 has no problem whatsoever keeping up with heating demand. I have recirc pumps on my zones and my loops are typically 200' each. I usually have all 8 zones firing at once. My system is an injection system with a Tekmar 361 as the heart of the mixing. I would think our temps would be similar. Don't let the complexities of it overwhelm you. Once the 105 is burning, it is worry free, and adjustment free. The learning curve is troubleshooting your system.
Thanks for all the feedback!
I am moving ahead (today if possible) with the Harman, if I can get one! I have a good local dealer (actually 3 within 30 miles to choose from).
I am sure I will have more questions.
talk you soon...
alaz
Your in PA ????
Why aren't you thinking Anthracite Coal fueled boiler??? and I am not referring to the 8 month backlogged Harmon VF3000 Coal boiler ;)
My goals were to save money and go green. I looked at a keystoker and did not go ahead because of high ash removal and more CO than oil. Otherwise I liked the system.. .
They are also backlogged, though not as far.
Anthracite coal ( not Bituminous Coal ) has less CO than oil - second only to Natural Gas
You will have LESS ash drama with Anthracite than you will have with pellets - plus you will only burn about half the volume as there are that many more BTU's per pound vs any hi quality pellet fuel - Anthracite will not go bad from improper handling or weather exposure - it will burn wet dry - this year or ten years form now!
I think your passing up an opportunity!
Coal may be my best cost alternative, but I spent an hour or so last weekend looking at rice coal, and I just was not comfortable with it. Bagged is 285 a ton ($55 more than pellets) and I know there is approx 5000 more BTU, but the annual savings was just not enough to make me get over how I felt...
But from a pure economic slant (and there is nothing wrong with that) coal is the better option, but I have to go with what I feel most comfortable.
By the way, Stephen, I put my order in today for pb105 and told dealer of your problems with ignitor. He confirmed there was a bad batch for some time. Said something regarding a solid black? wire connection. New and improved ignitor has blue line in wire.
maybe you can check yours.
Hope that helps.
Thanks Alaz, Good luck with your system, drop me a line if you have any more queries. I'll check my igniter wires.
Hey! That's the first new bit of information on the igniter issue I've heard beyond the "bad batch of igniters" story. I'll have to look into that info and see what my last (failed) igniter looks like.
Still think it's BS that Harman didn't recall if the "bad batch" story was true.
Hope it is though!
