woodconvert said:
Jags said:
woodconvert said:
Cuts easy with a chainsaw, splits easy with a splitter .....
Yer elm is different than my elm, thats for sure.
Prolly not. My splitter will shear a piece of oak so a stringy piece of elm isn't difficult to split, by hand is a totally different ballgame. As for cutting it i'm really surprised it's tough on your chain. Do you have a safety chain or a chisel chain???. I've got a chisel chain on mine that's far from being new and it eats it up. Maybe the weight of my saw makes it cut better????....but that doesn't splain the non-dulling chain. I'm stumped (no pun intended).
I use a chisel chain on my ms-361 and my splitter is a 5" ram cranked up to 2500 psi. Yes I can cut 6" white oak sideways with the splitter, and I can run a 25" bar, buried into oak a throw a rooster tail of chips. Thats not the point. If COMPARING elm to other firewood, I would say that "easy" is not a proper description. If comparing to concrete pillars maybe, but not other firewood.
If I were told that the elm works up easier than white oak, or ash, or whatever, I will say it again, your elm is different than my elm.
Unless you consider this easy:
and I had an entire tree act this way, not just a stump or two.
