Masonry vs. Stainless Steel Chimney
beagler7694
26
MI Thumb
What is better for an exterior chimney, a masonry chimney or a stainless steel chimney in a chase? I have been waffling back and forth and everyone has an opinion. Thought I'd finally just ask the experts. I know it is better to have an internal chimney however that is not possible. Price is comprable. $1200 to $1500 for the masonry, $1500 to $1800 stainless.
Both are functional. Masonry chimneys have been around forever and are proven. That said, I have an exterior masonry chimney, burn 24/7 Nov.-April...if I had it to do over again i'd go stainless in a heart beat. Based on friends who have stainless chimneys, they are more forgiving when burning not perfectly seasoned wood (seemingly less creosote buildup), they heat up quick but don't seem to have as much overdraft or runaway problems (that i've heard anyhow) and the stuff seem to be durable and lasting. I've yet to hear a complaint from one of my buds about their S.S. chimneys.
It's your call...either way you can heat your house, both have proven track records....one is just a bit more fussy than the other but you can learn your way around that (though, if you don't burn 24/7 I advise you to go with stainless....less wood consumed to heat it up. It takes A LOT of heat to get an exterior masonry chimney hot)
Properly installed, I'd go for the stainless in an insulated chase. My reasons would be warmer stack, easy to clean, proper sizing and tightly joined components. Then there is the coriolis effect so important for good draft. :)
A stainless steel class "A" chimney tested to UL HT-103 standard is hard to beat. Steel expands and contracts more readily than masonry, and so is less prone to thermal shock. In an insulated exterior chase you will likely have greater success with this than with masonry/terra-cotta.As others stated, it will heat up PDQ . any problems with "non self-starting" will be reduced as well.
blackgooseJT
