NFPA 211
I think that is for the entire code and not just section 211. 221 is like $38, but the whole shooting match is over $1300!
Standard for Chimneys, Fireplaces, Vents, And Solid Fuel–Burning Appliances, 57 pp.
Table of contents:
Chapter 1 Administration
Chapter 2 Referenced Publications
Chapter 3 Definitions
Chapter 4 General Requirements
Chapter 5 Selection of Chimney and Vent Types
Chapter 6 Factory-Built Chimneys and Chimney Units
Chapter 7 Masonry Chimneys
Chapter 8 Unlisted Metal Chimneys (Smokestacks) for Nonresidential Applications
Chapter 9 Chimney Connectors and Vent Connectors
Chapter 10 Vents
Chapter 11 Fireplaces
Chapter 12 Solid FuelBurning Appliances
Chapter 13 Maintenance
Chapter 14 Inspection of Existing Chimneys
Annex A Explanatory Material
Annex B Informational References
Index
If you're talking about "listed" as in a listed woodstove, that's not what NFPA 211 is about. It's a publication (one of many) put out by the National Fire Protection Association, and the title of 211 is "Standard for Chimneys, Fireplaces, Vents, and Solid Fuel-Burning Appliances". Most recently published in 2006. I have a copy on the desk in front of me in case you'd like to know more about it. It's not a tome, more like the size & heft of a catalog from L.L. Bean. It is, appropriately, bright red in color. Rick
KWillets said:
Is it flammable?
Most assuredly a combustible, yes. Rick
thechimneysweep said:
I have a copy on the desk in front of me in case you’d like to know more about it.
Rick, if you put up a sheet metal shield with a 1" airspace and non-combustible spacers, you'll be able to slide that booklet 12" closer to the stove.
:lol: Yes, I know, Tom, but thanks for the tip. It's close enough to the stove just where it is, for now. When the time comes for it to be closer, I'll go ahead and open the loading door. %-P Rick
