5.5" round Poly brush for titanium chimney - where to buy?
NewtownPA
246
Newtown, PA
I've been having a hard time finding a 5.5" round Poly chimney brush for a titanium chimney. Anyone know where to buy this unusual size? Would it be feasable to buy a 6" brush and use wire cutters to snip 1/4 inch off the ends of the poly bristles?
Titanium? I learn new stuff here all the time. If you don't mind me asking......... just how much is a titanium chimney per ft.?
Reactions: vetrano
I've looked high and far for a 5.5 brush with no luck. I ended up cutting down a 6" brush.
Yeah...stainless is bad enough. I've never even seen titanium chimney sections.
Very curious as well, Titanium?
Watch your chimney people have been stealing catalytic converters off of cars because titanium prices are so high! True Story!!! Where do you live again? :smirk:
It's standard 316Ti ("titanium-steel") chimney liner not solid titanium. 316Ti (UNS S31635) is a titanium stabilized version of Type 316 molybdenum-bearing austenitic stainless steel. The Type 316 alloys are more resistant to general corrosion and pitting/crevice corrosion than the conventional chromium-nickel austenitic stainless steels such as Type 304.
Anyway, I bought it from Rockford as a kit:
http://www.chimneylinerinc.com/
So yeah, looks like I'm going to have to buy a 6" and cut it down to 5.5".
Are you sure they didn't sneak you a '316 Ti" stainless liner and just call it 'titanium' (hope they didn't charge a bunch extra)
http://www.azom.com/details.asp?ArticleID=2868
316Ti
Another variation of 316 is available. This variation is 316Ti. Stainless steel 316Ti contains a small amount of titanium. Titanium content is typically only around 0.5%. The titanium atoms stabilize the structure of the 316 at temperatures over 800°C. This prevents carbide precipitation from the grain boundaries and protects the metal from corrosion. The main advantage of 316Ti is that it can be held at higher temperatures for a longer period without sensitization (precipitation) occurring. 316Ti retains physical and mechanical properties similar to standard grades of 316.
With that said, even a 6" brush was tight in my 6" liner if you did get one to work, it might easily be a one way trip (you'd never get the bristles to reverse direction inside the flue) The thought of clipping all those bristles made me cringe - but I did have good success running it for a few seconds on a belt sander to shave a bit off the tips.
-PS - fast typer! I see you've already got the Ti sorted out.
Same boat as you last year. I bought a 6" poly brush and spent some time cutting it down to size with side dikes. It took some time but works fine. No way would a 6" brush worked for me.
Dykes are a hand tool that cuts wires. etc. Can be had at any local hardware store or box store.
Ignore the "click to enlarge".
  • 5.5" round Poly brush for titanium chimney - where to buy?
Short for Diaignal Cutting Pliers I think. My 6 inch S/S liner ended up a little oblong rather than round after installation which makes it diffucult to get a 6 inch wire brush through it. Do the poly brushes work easier?
I thought it was poor idea to use steel brushes on on ss chimneys to begin with.
Thanks for covering that question for me Hog :p While I am at it you don't happen to have any towers laying around in pieces or some copper laying around from some work you might have done around your state in Pa. :vampire: Seems there is a radio tower missing in your state on the news I read.
I have some copper slides left from my roofing days working on slate roofs.
I have no tower, wish I did, steel is like $17.00 per 100 lbs here at the scrap yard.
Ok fuggers, here ya go, don't say I never found something no one else has. ;)
5-1/2" poly brushes, they will custom make anything you want.
http://www.caseybrush.com/custom_polyclean.html
And for the last GD time, steel or poly, both work fine, I'll stick with steel.
Hogwildz said:
Ok fuggers, here ya go...
Indeed we are, especially during initial break-in fires.
fugnoun. Stale air, esp. the humid, warm, ill-smelling air of a crowded room, kitchen, etc.
Rick
Last year when I went looking for a 5" poly brush I had no luck with the hardware stores. On the other hand both the Regency and the PE dealers had them. Have you tried a fireplace dealer near you?
Same here. Only took five minutes or so... probably shoulda cut a little more off, it's still a tight fit. But that liner comes out CLEAN!
Eddy
