I`m having a hard time understnding how pellet fines can be problematic with regards to the auger.
How can wood dust plug up an auger? Or isn`t this what happens?
Hmmm...it's kinda hard to explain, but I find that the fines tend to be packed against the feed tube by the auger over time and the pellets no longer have a smooth surface around the outside of the feed tube to slide along as the auger turns. That has been my observation anyway.
My guess would be, that it could cause a couple of issues.
1. Alot of fine sawdust would build up at the bottom of the auger and not allow the pellets to be taken from the bootom and sent up.
2. It could pack down and cause friction/resistance on the auger
3. The fines could get into the motor and or soak up any lubrication the motor has.
I have not had my stove long....but every few bags, I let the stove run out of pellets. I then use a wand attachment to my vac and suck it all out clean.
for the most part they make it to the slide plate, and fall on the back side of the slide plate (access cover), and then bind the slide plate.... which strains the auger motor.
On Harmans
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
