Pellet stove fire starter
4dimad
49
MA
Hello everyone,
I finally installed my Harman P38 with manual lighting . ... and just realized how expensive the fire starter / gelled alcohol is.
What can you recommend instead or suggest the place where I can purchase gel for reasonable $$. Thanks!
Dima
I am not in MA, but I found some at Walmart.
This question comes up often.
I find using a propane torch with a push button igniter works great.
I use one of these
http://www.bernzomatic.com/PRODUCTS...etail/mid/1009/xmid/6942/xmfid/3/Default.aspx
I see them at Home Depot for around $20.00
Start up stove.
Throw in a handful of pellets into the burn pot liner.
Light torch and direct flame onto the pellets.
Allow flames to get established.
Close door and enjoy heat.
No messing with gels and sticks.
It works for me.
---Nailer---
I had an old timer recommend the use of a coffee can, handfull of pellets and some kerosene. (Im sure you can figure out where Im going with this) He also told me to (I bought my p38 from him) not to light it according to the instructions (Ive posted this already so sorry for the redundancy) He told me to keep the pellets to the front of the firebox, so there is a 1/2 inch space in the back exposing like 25% of the auger. Be said to light the fire in the back/bottom so that it doesnt burn from the top down.
I also gotta tell you, be careful with those gel lighters. If you think it needs more once you light it, remember the flame can and will travel right up the stream of gel, much like lighterfluid and charcoal. Ive seen the after effects of one of them suckers exploding and covering a room and occupant in burning gel. (sorry, This is probably wasted information on all here, but if something ever happened and I didnt mention it Id feel like a jerk)
Stay warm and safe
E
walmart...$8 a bottle
I hear the hand gel disinfectant works and it's cheaper. Also denatured alcohol in a can mixed with the pellets works well, burns very hot.
After much money spent on starter gel , propane torch and a lot more experimentation I`ve come to the obvious conclusion that odorless / smokeless charcoal lighter is actually better and possibly even safer than the gel for these reasons.
1......You must hold the match to it momentarily to light as it lights lazily and kinda slow as it does not flash ignite like gelled alcohol does. It isn`t as volatile as the gel.
2......It burns as cleanly and long and maybe even longer than the gel , and surely long enough to start your pellets.
3......the flame is considerably higher and hotter resulting in significantly shorter heat up times.
4......It cost only $2.49 for a quart and goes much farther at 1/3 the cost of gel.
As with any combustible materials certain precautions and common sense must be taken.
I would implore users to mix pellets and charcoal fluid in a plastic bowl and not in the stove burn pot. (leave no excess fluid in the bottom of the bowl) The saturated pellets can then be poured easily into the *cold* burn pot and lighted safely with a match or butane lighter.
Always be sure the stove exhaust fan/combustion motor is running to evacuate any possibile accumulation of fumes.
with my old mannual start pellet stove all i use was a propane tourch with a trigger $30 at lowes lasted the whole season even bought an extra can of propane used it for cammping trips to start our fires
Oh yeah, I almost forgot. Another option is to blend in 4-6 ounces of isopropanol (91%) alcohol with the 16 oz of starter gel. It will work better and lower the cost.
I think a qt of it is about $1 or so in a discount store.
Before I got my new stove, I bought a couple of cases of the stuff from HD at the end of the season and it was super cheap, like $0.75 a bottle. Of course that does not help you now. I found for the money the cedar flakes worked better then the gel.
The following is a PSA......
please dont use charcoal starter/ lighter fluid /gasoline or anything else along these lines to start a fire in a enclosed vessel.........IN YOUR HOUSE.......
this has been run through over and over and over.....
use a......
torch
gel
hand sanitizer
vegetable oil
heck I even started a stove with one of those long lighters for candles
I'm sure there are others to start a fire safe that I have missed..........
My Harman invincable insert had to be light by gell also. I found them at wal-mart and TSC and Agway and True Valuehardware stores stores these compressed fire bricks. The box clerley states for use in wood stoves/fire places and pellet stoves. I never had a problem with the brick once it burned , it had no problem lighting the pellets. You just stick the match on it and it lights.
Good find! I saw it there today at $8 and that`s a *quart bottle* vs the chintzy pint they scam you $8-13 for at some stove shops.
I saw the $8 gel at Wallyworld yesterday, but decided that was still too much $ to start a fire. I decided to buy a quart of 91% IPA instead as it was a fraction of the price. I removed the cap and punched a small hole through the sealed foil so I don't have to worry about pouring too much of it. I took a small Tupperware container (1 or two cups), threw about a cup of pellets in it, squirted a little of the IPA in it (just enough to wet most of the pellets), gave it a shake and poured the pellets in the P38... Threw in a match and had an instant fire, worked great. I tried it again today w/o any issues, probably took 10 seconds to grab the pellets, wet them with the IPA, and light them in the stove.
Hey that`s great! Whatever works for you.
4dimad said:
Hello everyone,
Dima
$8.00 a bottle isn't too bad once you realize that you don't need a lot of it to start the fire. A thumbnail size dollop of gel is all I needed to start my stove.
Unless you're one of those people who try the BBQ method of loading the coals up with 1/2 a can of lighter fluid lol
CygnusX1 said:
4dimad said:
Hello everyone,
Dima
Loading up coals with 1/2 bottle of gel will get you the same results, maybe worse.
I have used the gel (fast, but expensive) and now use "squares" made from what appears to be paraffin-soaked fiberboard.
They light instantly, but take a few minutes to get the pellets going. Cheap works for me.
