- Nov 19, 2005
- 54
have anyone noticed a change in chainsaws or small motors using ethaneol, my saw start running at extreme high speed used it in about 3 tank fulls then change back to gas with out ethaneol running better THANKS
i make sure my saw gas doent have it! You can run it if you ajust the carbtnroadkill said:have anyone noticed a change in chainsaws or small motors using ethaneol, my saw start running at extreme high speed used it in about 3 tank fulls then change back to gas with out ethaneol running better THANKS
smokinj said:i make sure my saw gas doent have it! You can run it if you ajust the carbtnroadkill said:have anyone noticed a change in chainsaws or small motors using ethaneol, my saw start running at extreme high speed used it in about 3 tank fulls then change back to gas with out ethaneol running better THANKS
Stihl web site says its ok! i dont unless i have to, small carb adjust is all it takes.taxidermist said:smokinj said:i make sure my saw gas doent have it! You can run it if you ajust the carbtnroadkill said:have anyone noticed a change in chainsaws or small motors using ethaneol, my saw start running at extreme high speed used it in about 3 tank fulls then change back to gas with out ethaneol running better THANKS
If you run your saws with it in it you are asking for a meltdown! use BP ultimate and good oil and you will not have any problems. I get to make lots of money from rebuilds do to todays fuels.
Rob
smokinj said:Stihl web site says its ok! i dont unless i have to, small carb adjust is all it takes.taxidermist said:smokinj said:i make sure my saw gas doent have it! You can run it if you ajust the carbtnroadkill said:have anyone noticed a change in chainsaws or small motors using ethaneol, my saw start running at extreme high speed used it in about 3 tank fulls then change back to gas with out ethaneol running better THANKS
Rob
Rob
if its not running good get rid of it and go with 93 octane til you get it broke in.B.P. 93 octane gas is really god saw gas as mention,but not always easy to get to.Badfish740 said:I'm new to this whole game just bought my first saw (Echo CS400) about a month ago. I bought a gallon of regular gas (87 octane) and mixed it up with oil the proper proportions and proceeded to use the saw. I had a hell of a time cutting into a 6" diameter pine tree and I thought that maybe thought the chain was new that it needed to be sharpened. The saw bogged easily and just didn't seem to have enough power-is this due to the ethanol content? It was listed on the pump as 10%. What can I do to give the fuel a little extra kick-octane booster? In my turbo four cylinder days we used to add toulene to Sunoco Ultra 94 to get the octane rating up above 105, so adding some to this batch ought to get it into the mid 90s easily. Otherwise I can just dump this batch in my Toyota pickup-one gallon of mixed fuel shouldn't be that big of a deal diluted in 20 gallons of straight gas.
smokinj said:if its not running good get rid of it and go with 93 octane til you get it broke in.B.P. 93 octane gas is really god saw gas as mention,but not always easy to get to.
That will work!Badfish740 said:smokinj said:if its not running good get rid of it and go with 93 octane til you get it broke in.B.P. 93 octane gas is really god saw gas as mention,but not always easy to get to.
I've got a Sunoco around the corner from me so they should have 94.
taxidermist said:The only reason I say BP/Amaco is they have the lowest or none in their gas You can run any gas as long as it is high octane and low EA.
taxidermist said:The only reason I say BP/Amaco is they have the lowest or none in their gas You can run any gas as long as it is high octane and low EA. I too would rather give money to the farmers but I dont want to have to rebuild my saws at a toon of 300.00 per shot.
lobsta1 said:taxidermist said:The only reason I say BP/Amaco is they have the lowest or none in their gas You can run any gas as long as it is high octane and low EA.
BP/Amoco has the lowest or none of WHAT in their gas? What is low EA?
I agree with you & do run 93 octane in my saws. Around here we have no choice about ethanol. It was crammed down our throats. Doing all the work myself, it ended up costing me about $5000 to replace my perfectly good fiberglass gas tank in my boat. Had to rip a teak deck up, sawsall out a bulkhead & then a perfectly good 275 gal. tank. Had new tank built & fabricated custom hold down brackets. Re-glassed the bulkhead back in & then re-did the deck. I was NOT a happy person. It was either do all that or risk losing both 454 engines. I DON'T LIKE ETHANOL!!
Al[/quo
I ment E or Ethanol they have the lowest amount in our area.
