Storing a days worth of wood hearthside
jamkam
51
SW Conn.
As we await (impatiently -- it's dipping into the 30s here in the NE already!) the arrival of our PE insert, we've been looking around for a good size but compact (i.e. tall?) rack that'll hold a days worth of wood on the hearth, preferably something like a bin that will also keep the debris to a minimum. Anyone find anything? The bins and racks I've seen are either too small or too deep. Also, if you can post a cpl of names of reputable source (Plow and Hearth is the only one we know of), it'd be appreciated.
TIA, y'all
a big storage tote from dare I say Wal Mart it is cheap and will contain the mess. when you get a lot of crap in it you juast take it out side and empty the crap out of it.
Although they're not so critical for wood storage in this house, I have two brass tubs that are 2 ft. in diameter and 2 ft deep. I bought them to store wood by the fireplace while living back east. You might check flea markets for something like that. (I'll admit that I bought mine in a shop in Alexandria Old Town that specialized in brass fixtures and I paid too much for them. I suspect you can find some kind of neat metal tubs for reasonable prices at a flea market.) In this house, I keep kindling in my brass tubs because the stone/masonry alcove that houses the wood stove has 2 built-in storage areas that allow me to store about 3-4 days worth of wood inside the house.
That's exactly what I bought. I'm pretty sure it was a 37 gallon with lid for about $10. I made sure to get a brown one to match the room decor. That way, the wife does not complain. ;-)
thanks, but we're spending an arm and a leg on an insert, want something a notch above Sam's.
the tubs are nice...plow and hearth has them for close to a hundred clams. anyone seen them anywhere cheaper?
I got a couple of these Link. These baskets have a closed bottom and keep the dirt contained inside. The possibilities are endless.
Spend a couple more $ and get the one with wheels. The suckers are heavy to drag back through the house when full.
If you think the look of a galvanized wash tub would match your decor (or are willing to paint one) you should be able to find one at reasonable prices. Locally, you could try a farm supply store. Online, check out The Bucket Outlet. They've got 17 gal. plain, galvanized wash tubs for right under $30 (there are smaller sizes for less, too). Or, if you want fancy, they sell embossed copper-plated buckets. If you have local flea markets, I'd check them out, too.
Just a note about the big tote/wood carrier that is sold at Lowe's. I am looking for one so I checked their's out. It contains lead and there is a warning on the box and carrier that clearly states this. I was really surprised to see that and I didn't purchase it. Probably because of the paint on the carrier. I know I can find just a plain canvas one so I will keep looking.
TIA, y'all
Is your wood supply in an enclosed woodshed? If not, factor in that it will shed some water and/or need to warm up and dry out a bit before you throw it on the fire.
If you're looking for strictly utilitarian, Gardeners Supply has several sizes of black plastic boot trays with a grid-like insert sold separately that have totally done the trick for me. I have one of these just outside the hearth for easy reach and another on the other side of the room for drying/dripping. Personally, I rather like the look of a stack of wood, so don't feel the need for a fancier container. The black plastic trays are totally unobtrusive and you can't ask for better for catching drips and loose debris.
For bringing wood in, I haven't found anything better than sturdy cardboard boxes.
I like this carrier by Vogelzang from Harbor Freight. It's made with antiquey metal and I think it looks good. I painted the gray wheels black to blend in a little more. The large wheels go over steps a easier than the small ones. It makes it easy to bring in wood from the garage. It is loads better than lugging the canvas carrier: I can close the door behind me easy, it saves my aching back, and avoids one more load/unload activity.
I have a closet in my computer room that just stores junk. My computer room is off of the room that has the stove.
I cleaned out the closet, lined the walls from the floor up to half way with thick plastic and BANG, wood storage for me.
It now has a chance to dry out (if need be) and I can fit a bunch in there (days worth)
