x96mnn said:Up stairs I installed EF3Bi with nickel trim door kit...heats up to 2000sq ft so heating the top floor which is 1120 is no problem. Stove works very well and on the level I run it can get a little over 2 complete days from a bag.
Gio said:x96mnn said:Up stairs I installed EF3Bi with nickel trim door kit...heats up to 2000sq ft so heating the top floor which is 1120 is no problem. Stove works very well and on the level I run it can get a little over 2 complete days from a bag.
Over 2 days from one bag? That`s got to be phenomenal !
macman said:Gio said:x96mnn said:Up stairs I installed EF3Bi with nickel trim door kit...heats up to 2000sq ft so heating the top floor which is 1120 is no problem. Stove works very well and on the level I run it can get a little over 2 complete days from a bag.
I agree...2 days from 1bag would be amazing, but I'm wondering if he meant "from 1 FILL" of the hopper?
x96mnn said:The hopper to me appears to be full, no expert in Pellet stoves but am using a 40IB bag of Shaw wood pellets (produced in the Maritimes)
I would fill the hopper Sunday between 8 and 10am and the stove would burn Sunday, Monday and run out while I was at work Tuesday if I would forget to top it up Tuesday morning.
As for throwing heat it does just fine although it may be my perception only with the enviro max doing the blunt of the work keeping the floors warm down stairs.
hearthtools said:x96mnn said:Repairs were made to the stove today, (yes it took too long), and I am sad to report it did not resolve the problem entirely! Made it definitely better but there is no way this stove will be capable of being hooked up to a thermostat and shut down and relight without the burn pot being cleaned out.
I started the burn around 11:00 today and when I came home around 7:00 the pot was about half full in the middle and clear around the sides which I thought not bad, it�s still burning and not over flowing with the side bottoms being seen. Impressed to this point I tried a shutdown which to my dismay at the end the pot in the middle has about a half inch of what looks to be well burnt pellets.
What next? Not what I expect from a $2000 machine!
You got a good deal at 2K
the list price $2200
Plus around $398 for large glass door
or $300 for small glass door
Most standard pellet stove are over 2K
the Omega list price is $4200
