CDodge04 said:I try to keep the house between 64 and 66 degrees at all times...plenty warm for me. The lady of the house likes things slightly warmer (100 degrees), but due to the costs involved I generally win.
I leave my hot air furnace thermostat on 58 degrees so that incase the stove cuts out in the night the furnance can keep things warm enough until I get the pellet stove going again.
Doocrew said:CDodge04 said:I try to keep the house between 64 and 66 degrees at all times...plenty warm for me. The lady of the house likes things slightly warmer (100 degrees), but due to the costs involved I generally win.
Ditto.
Jim41 said:Yup...60 is what is set on the thermostat upstairs. The oil burner has been kicking in as I am not really attempting to get good overnight burns. By the time I'm going to bed, the coals in the stove are pretty deep and throwing alot of heat so I just let them burn overnight on low. If needed, I throw a couple of logs on when I get up to take the chill out of the first floor.
macman said:Jim41 said:Yup...60 is what is set on the thermostat upstairs. The oil burner has been kicking in as I am not really attempting to get good overnight burns. By the time I'm going to bed, the coals in the stove are pretty deep and throwing alot of heat so I just let them burn overnight on low. If needed, I throw a couple of logs on when I get up to take the chill out of the first floor.
Jim, I think you posted on the wrong forum....you want the Hearth Room for wood burners.
jimmy carter would be pleasedzeta said:67F during the heating season.
72F during the summer.
Jimmy Who?xpellet freakx said:jimmy carter would be pleasedzeta said:67F during the heating season.
YIKES! :gulp: I won't be visiting anytime soon.....and I thought my house was cold last year when I had the oil burner set for 67....Aaron Pasteris said:Normal Temp - 63°......Aaron
macman said:YIKES! :gulp: I won't be visiting anytime soon.....and I thought my house was cold last year when I had the oil burner set for 67....Aaron Pasteris said:Normal Temp - 63°......Aaron
Aaron Pasteris said:.....Even with the thermostat set that low, I burned 1.5 ton of pellets and 800 gallons of oil last year to heat. Had I set the temp to 70° the oil guy's kids would be going to Harvard on me!
Aaron
