Hansson
Titus said:It does not help in your desire to convert what you already have but....
There are dryers designed to exhaust indoors, called condensing ventless dryers. I have been doing some research , and this is the type I will be buying to replace my 16-year old electric dryer. In the condensing dryer, the hot air in the clothes drum cycles though a closed loop. Moist hot air passes through a condenser which removes the water. Hot dry air then returns to pass through the clothes again. The moisture is collected in a bin or pumped out to the same drain the washer uses. Some devices use a loop of cool room air to chill the condenser. In some models, particularly the wash/dry combo machines, cold water is used to chill the condenser. In either case, there is no vent and no lint blown into the room. The waste heat end up in the laundry room. This would not be good for areas where cooling is the greatest utility cost, but up here in Maine, I'd rather have the heat stay in my house. The two months a year I would get a hot laundry room aren't a big deal.
These are mainly European designs. I haven't seen them in the appliance store, but they can be ordered. They are made by such companies as Bosch, LG, Eurotech, Equator and Miele.
Costs appear to be in the range of the expensive dryers that match the new front load washers.
Here is one by Bosch...
http://www.ajmadison.com/cgi-bin/aj...=Google+Products-_-00271-_-Bosch-_-WTE86300US
I am seriously considering a combo unit since my washer is old too. An LG example...
http://www.newegg.com/Product/Product.aspx?Item=N82E16896140060
Thor Appliances makes and sells such machines.
http://www.thorappliances.com/
I know that electrolux newest condensing ventless dryer have a heatpump inside.
It needs 50% less energy that a ordinary condensing ventless dryer like those you link to.
http://www.electrolux.se/node38.aspx?productId=28262
No info in English unfortunately
I have a condensing ventless dryer and I dont use it much.They need much energy.
