MCPO
Mattman193 said:GVA said:If that is truely carbide I would hesitate to use it on the mild steel burnpot.Mattman193 said:My dealer gave me this big carbide scraper and told me to really get in there and scrape the burn pot weekly with it. He said the Harman tool is fine for light cleaning and getting into hard to reach places like the auger tube. Other than those two tools, I have a screwdriver and a paint brush.
A screwdriver bent works fine but even this is harder than the burnpot.
the idea is to have it sharp enough to get the edge under the clinkers and they pop right up.
Yes, it is carbide but you have to use your judgment when you use it- it doesn't mar the metal when you scrape with it. I'm sure you can do way more damage going after the carbon with a chisel and a hammer. I really don't get that much build up on the burn pot since I stopped burning Marth pellets. Once weekly I shut the stove down and vacuum it out and scrape the burn pot- most of the carbon is right in the front of the pot. At most it takes me 30 minutes to scrape the pot and pull the removable panels to clean the heat exchanger and exhaust fan.
30 minutes to scrape the burn pot?
It`s not so much the hardness of the scraping tool but the adhesion of the carbon buildup that presents the problem. A screw driver puts more pressure on a smaller area than the Harman tool and therefore makes it easier to remove.
I`ve not heard of any tool marring the burnpots, even judicious use of a hammer and chisel. I mean who`s gonna use a 3lb hammer to loosen a bit of clinker?
