t300p triditions problem
baffold
1
michigan
I have a t300p and the control board will not let me adjust the combustion air. The manual says that you push the calibrate button twice to activate the combustion air calibration mode but always goes back to operational mode. Can anybody help?
Good evening baffold,
As far as I can remember, the Traditions stoves does not have a combustion air calibration but only the fuel feed calibration. Look on the back of the control board and you should see something like ver 1.11 or ver 1.01 - The profile series stoves have both the feed and draft calibrations. If in doubt you can always call Lennox Hearth Products customer support.
I thought the profile 30 & Traditions control board were the same part number? There were several profile 30 boards that didn't have the draft calibration as well.
