I think that I may start using one. I sometimes feel a sinus / throat tickle after cleaning the stove.
The shop-vac gets the other 99.9% of the dust.
pkitfox said:Get a good filter for the shop vac. Use a mask rated for sheet rock dust, or better. You may not drop dead from breathing small amounts of dust, but we really don't know the long term effects. The outcome can be different for different people (like some people can smoke all their life, and others die at 30 from smoking). Why take the risk. Protect yourself, as best you can.
Maybe some Pros will offer up information on what they are using.
Cut a hole in it.GotzTheHotz said:How am I suppose to smoke with a mask on?
Wet1 said:Cut a hole in it.GotzTheHotz said:How am I suppose to smoke with a mask on?
Wet1 said:I have the vacuum setup outside when I clean my stove. I run a long hose in through a window (use a towel to block off the remaining window 'gap'), and this keeps the vast majority of the dust and noise outside the house. I also take the filter out of the vac since it's outside, so there's no clogged filters, or even special filters needed.
CZARCAR said:i confess i snort the dust just 4 the fun of picking my nose after. unlike cleaning the glass with ashes, i eat the boogers. havent tried licking the glass but still thinkinnnnnnnnnnnz
I fail to see how it can't be a least a little bad for you. Either way, why take a chance when dust masks are so cheap?OU812 said:Lots of posts about this but is pellet ash really bad for you?
