stihlwoody said:I was under the impression that taco pumps were to be mounted horizontally, not vertical?
stihlwoody said:stee...
Steve
rvtgr8 said:These are three speed Grundfos. I was told, maybe erroneously, that these could be mounted vertically. I did not see anything in my literature, but if I am wrong, now is the time to change it.
rvtgr8 said:The ball valve is almost seven feet away from the Garn on the supply side, while the return side is right at the manifold. Is this a deal breaker?
rvtgr8 said:I have a question. I am assuming pipe dope will work as well as teflon on the HX. I doped the male threads and the female threads in the connector as well. I turned the fitting by hand (4 turns) until it was no longer possible. I then took an 18" wrench and turned the fitting an additional 1.5 turns. I know I could have gon a bit farther but am afraid to put too much pressure on the HX. My question is simple, does this sound like it will sufficient to keep it from leaking?
Robert 8-/
WoodNotOil said:rvtgr8 said:I have a question. I am assuming pipe dope will work as well as teflon on the HX. I doped the male threads and the female threads in the connector as well. I turned the fitting by hand (4 turns) until it was no longer possible. I then took an 18" wrench and turned the fitting an additional 1.5 turns. I know I could have gon a bit farther but am afraid to put too much pressure on the HX. My question is simple, does this sound like it will sufficient to keep it from leaking?
Robert 8-/
It will probably be fine. You will know if it is not though! I assume you put in unions and you have a way of isolating it. If it does leak, then isolate it, take it off, and tighten it. Sometimes it helps to heat the doped joint before trying to turn it. However, I don't see it being a problem.
Rick Stanley said:Generally speaking, would putting dielectric nipples on either side of a ball valve make distance from the tank, less of an issue? Or? How does that work? Do dielectric fittings accomplish the same thing as keeping yellow metal FAR from the tank?
