xpertpc
That looks pretty nice so far and went to town with 10 copper pipes, what did you use as a backer board to screw the plates to? don't forget to mount with a slight slope so the tubes will drain.
Regarding the cost of the solar system, checkout the following link. It does a good job showing how big of an impact cost is when considering the payback. You'll need to know some basic info about your system to get accrate numbers, but either way it's kind of neat to see how build cost impacts payback.2.beans said:im at $226 so far. thats with buying enough screws and 1/3 of the wirsbo plates to build the next one. im not sure on the heat rating of the insulation, i didnt put that much thought into the 250 plus temp. thanks for pointing that out. i dont know if i could change it now without breaking something. i already bought the high heat paint and used some so i guess ill stick with it. if it fails i can always take the glass front off and repaint. thanks for the much needed input.
You kind of lost me here. How are you going to configure your system? Is it going to be a batch, thermosyphon, drain back, or closed loop system? Here is a LOT of info on solar hot water heating design which you might find very helpful...without sounding too dumb about the drain back, i planned on draining this in the winter. this would give me room to add treatment to my system every spring. each collector holds 1 and 1/4 gallons of water. the collectors are going to be at my shop which is 250’ from my 1000 storage tanks. when my super store tank (dhw 45 gallon tank) calls the panel will directly heat the dhw, if there is no call it will dump into the 1000 gallon storage. i guess im not to sure on how the drain back works. i wasnt planning on doing it with a drainback because i burn wood in the winter. in the worst case if this doesnt work like i hope i can put the panels down at my pool and try to heat that. thanks.
so if your tank temps at 100* the pump turns on at 115* and shuts off at 105*? does it automatically rise as the tank temp rises? when you say that you hit 160* yesterday was the collector temp or storage temp? the ranco is a differential controller im not sure if its the best one for the this application though.thanksWallyworld said:You need to use a differential controller, which I assume the ranco controller is. Mine turns on at 15 degrees warmer than water temp and kicks off at 5 degrees warmer. I have 2, 3 by 8 panels, copper collectors and I hit 160 degrees yesterday. I'd say your collector did pretty well
2.beans said:so if your tank temps at 100* the pump turns on at 115* and shuts off at 105*? does it automatically rise as the tank temp rises? when you say that you hit 160* yesterday was the collector temp or storage temp? the ranco is a differential controller im not sure if its the best one for the this application though.thanksWallyworld said:You need to use a differential controller, which I assume the ranco controller is. Mine turns on at 15 degrees warmer than water temp and kicks off at 5 degrees warmer. I have 2, 3 by 8 panels, copper collectors and I hit 160 degrees yesterday. I'd say your collector did pretty well
In Gary's article under "pumps and controls" he uses the Steca differential controller, They seem to be $100-$200 depending on needed features, I just google searched and came up with this http://www.stecasolar.com/index.php?Steca_TR_0502_en2.beans said:what kind of controller is it? thats how id like to run it.
