Gooserider
Mod Emeritus
Medman said:I think I am going to have some difficulty adapting this fan to my chimney, since I come out of the boiler and transition from 8 inch double wall black pipe to 7 inch double wall pipe. I don't know how well I can adapt the fan's 6 inch outlet to the 7 inch pipe.
I'm not that impressed with the wiring for the fan either. I think I will change the configuration for safety's sake.
The fan does move a lot of air at max speed. I think it will provide more than enough draft when loading the boiler. I do not intend to run the fan when burning normally.
I agree on the fan wiring... It looks very "Mickey Mouse" to me, and I have trouble believing that it would meet any sort of code listing... The only time I've ever seen that sort of spiral wrap over individual conductors setup is either in a non-AC application, or with a motor that is hard wired into an appliance such that the wires were NOT exposed to normal users... If temperature is an issue, they make high temperature line cord material, so that shouldn't be the reason for the odd setup. I'm not an expert on UL etc. stuff, but my recollection is that they generally want to see any sort of line cord drawing more juice than a table lamp, or anything permanently installed (which IMHO the inducer would be considered to be) to have a jacketed type cable to protect the conductors from harm, and that spiral wrap doesn't cut it in that regard... OTOH the controller wiring looks fine.
The other thing I was trying to figure out from the photos is how the unit moves the smoke through it... I assume there is some sort of squirrel cage blower or equivalent on the end of the motor shaft, but what is the air flow? Where does the smoke go in and come out? Maybe more / different photos from a different angle might help?
Gooserider
