netmouse said:You are right. As I revisit the decision, I need to review prior questions - I'm going in circles. The thread you refer to ends with a moderator saying "Everybody knows that Jotuls are crap. Only thing worse than a Jotul cast is a Lopi steel. " and I can't tell if he is being sarcastic or real.
Dont forget the F600 has the double front doors and one side needs that silly gadget to open it. I also wasnt a huge fan of the seashell emblem on the F600. That could be a much better seller if they made some minor adjustments. The Oslo was the right size for us and its by far the best stove I've opereated. The heat will last longer than a steel but the steel will heat up quicker.. boils down to personal preference.Deep Fryer said:I have the Oslo as well and I am very happy with it, but I now do wish I had gotten the F600, mainly with regard to over night burns.
Make sure you are getting the right size for your needs, regardless of which brand you go with.
Pagey said:netmouse said:You are right. As I revisit the decision, I need to review prior questions - I'm going in circles. The thread you refer to ends with a moderator saying "Everybody knows that Jotul are crap. Only thing worse than a Jotul cast is a Lopi steel. " and I can't tell if he is being sarcastic or real.
Rick was being facetious in that post. He owns a Lopi Liberty, and I'm sure he'll tell you that it's not junk. As others have pointed out, bear in mind you are comparing two different beasts: a cast iron stove and a plate steel stove. Jotul makes some of the best cast iron stoves on the market, arguably, and Travis Industries makes some of the best plate steel stoves on the market (Avalon and Lopi). You couldn't go wrong with either choice. I suppose one could argue that a cast stove might require more work over its life considering they can require a "rebuild" from time to time. However, plate steel stoves will eventually require the baffle system to be replaced, so maybe it's a wash.
netmouse said:I had been thinking of buying the Jotul Oslo 500. I am also interested in the Avalon Olympic stove.
Is there anything between these two to consider that is different or to compare in considering buying a stove?
