I am preparing to pour my garage floor. Should I put foam under the entire garage floor (24x36) or just foam 8 ft. in from the walls and have the tubes in the center on the sand?
I have heard there have been buildings where foam was put down and concrete poured over it and later it was pulled up for some reason and the foam was gone. The heat from the concrete setting melted the foam.
Mid Michigan said:I agree foam it all. I did the same on my last building.
BUT, Just to be the devils advocate, I have heard there have been buildings where foam was put down and concrete poured over it and later it was pulled up for some reason and the foam was gone. The heat from the concrete setting melted the foam. Has anyone else ever heard of this? If it is true kinda sucks on the investment.
yooper rich said:Thanks to all for the info. It sure helps having you folks to call upon. I have already installed two inch foam along the walls to a depth of two feet below the slab. This weekend I will be putting foam on the entire floor.
Don’t forget a vapor barrier, like 6 mil polyethylene.
E.W. said:The extruded foam is also a type 1 vapour barrier so you can poly if you want but it's not necessary.Of course you do have to tape the joints in the sheets of foam.I'm a belt and suspenders type so I used the 6mil poly along with the extruded foam insulation.
Earl
