Wow thats alot of snow for October.
Curious to see how long you get out of that setup- keep us posted
Excell said:MountainStoveGuy said:pellet burner said:Sorry to disappoint you MountainStoveGuy but you will get nowhere near 60 or 70 hours of run time. Amp hours are not calculated that way. By this calculator you will get 2.5 hours if you are lucky.
http://www.xantrex.com/support/howlong.asp
i have no idea... its been on batter power now for 16 hours. and the stove is running constantly in this cold weather.[/quote
I am sold ,I can't wait to see how long it will go . Have you got a meter to check the battery voltage to see when it starts getting low . I don't think you want to
be running with low voltage .
Still running this morning, if the voltage does get low, the control bord flips out and the stove will not run. I had a customer that installed a accentra insert on a switchable outlet. He didnt realize that the switch was in the off position during installation and the first 3 days where on the battery system without him knowing. He called me with some very strange error codes on about day 3. Harman could not figure out what the codes ment, so i went out and tested the outlet. No juice lol.
MountainStoveGuy said:I have a small float charger that puts out 750 mA @12 volts connected to the battery at all times.......
macman said:MountainStoveGuy said:I have a small float charger that puts out 750 mA @12 volts connected to the battery at all times.......
MSG, do you have the battery charger connected and charging now while you're running the stove off the inverter?
cozy heat said:90 amp hours / 1.5 amps = 60 hours, but you'd also have to figure in inverter efficiency which is usually around 50-60%, so you're probably looking more at 30 hours run time.
MountainStoveGuy said:macman said:MountainStoveGuy said:I have a small float charger that puts out 750 mA @12 volts connected to the battery at all times.......
I do.
That's what I wondering when i asked about the charger.amick780 said:MountainStoveGuy said:macman said:MountainStoveGuy said:I have a small float charger that puts out 750 mA @12 volts connected to the battery at all times.......
I do.
So, you are charging the battery while you were running the stove on battery? Wouldn't that skew your run-time?
MountainStoveGuy said:cozy heat said:90 amp hours / 1.5 amps = 60 hours, but you'd also have to figure in inverter efficiency which is usually around 50-60%, so you're probably looking more at 30 hours run time.
the inverter data says its 90% efficient. I got about 59 hours. The batter was not full when i started. I think i would change out the inverter to a true sine wave inverter. Occasionally it would "pulse" the electricity. In otherwords it would shut off then on within a few seconds, not really interrupting the burn, but annoying never then less.
MountainStoveGuy said:Well, we got 36" + of snow yesterday, and im surprised we did not loose power. I am not a good boyscout so i was not prepared if it did. I purchased a modified sine wave 600w inverter, a 90 ah deep cycle marine battery, and a auto top off/float charger that can be plugged in constantly to the battery. The Harman XXV draws 180w continuous power, which is ~1.5 amps. This set up should give me 60-70 hours of backup heat. (i hope)
MountainStoveGuy said:I ended up with about 5 days worth with the charger plugged in and working.
MountainStoveGuy said:the charger is only 750 mA, but still skewed my test im sure. Im going to test again when i get a good sine wave inverter. Perhaps the same model as the markas mentioned in another thread.
Markcas123 said:I recommend getting at least a 79AH sealed lead acid battery. They can be had for 160.00 or less.
I am sure you know this, but just in case, please make sure you get a sealed lead acid and not one for use outdoors only, like your auto battery.
macman said:Markcas123 said:I recommend getting at least a 79AH sealed lead acid battery. They can be had for 160.00 or less.
Like this? www.apexbattery.com/deka-unigy-24hr...--ups-batteries-deka-unigy-ups-batteries.html
I tried Froogle.com for a price, and the cheapest was $160 + shipping. This one is $200, but free shipping.
