RustyShackleford
53flyer said:... I'm used to most people talking about cats irt super long burns at "low" settings but during the middle of a cold winter the stove would need to be set higher than low all the time. That's why I was wondering what setting most BK burners felt they could set their stoves without worrying much about damaging the cat.
The way I look at it is, I only care about the super-long burn for running overnight.
I want to fully load the stove before I go to bed, have it run all night without the catalytic
becoming inactive (and thus inefficient and polluting), and still have a fire going in the
morning, one which can be raised to an inferno simply by opening the thermostat and
maybe adding some wood. I want this to work even if I don't want to have to pack the
stove RIGHT before beddy-bye, and if I want to sleep in (more than 8 hours). So the 12hr
I've been seeing works very nicely. I don't care if the house gets a little chilly, which even
on a low burn will only happen if it's below freezing (not that common in NC these days),
because I like sleeping in a cold room and have a thick comforter.
You cannot violate the laws of physics. You can only load so much wood in the firebox (MAYBE
60lb in the Princess, if you have BIG chunks of very dense hardwood), and this wood can only
release so much heat per pound (more if it's good and dry). So if you need to set the stove
to a higher temp, you're just not going to get as long a burn - sorry. If you set it so high that
damaging the cat is a risk, it's only going to stay that high for a few hours.
So, like others have said, it doesn't really make sense to set the stove to a high temp and then
abandon it, for two reasons: there's no reason to heat your house so warm if you're sleeping
or going out for the evening, and it may run out of wood. So I think your worry/question is
sort of moot. Hope this helps ...
